High intake temps, whats too high ?
Old May 22, 2012 | 12:58 PM
03LQ9's Avatar
Default High intake temps, whats too high ?
I'm running a rearmount on my truck at 10 psi with no intercooler yet. The intake temps go from 111F to 171F in a little over 10sec at wot with ambient temps in the mid 70s. Does this sound normal ? What temps should I get concerned at ? I'm using e85 and timing is 15* then tapers down above 150F.
Old May 22, 2012 | 02:31 PM
Atomic's Avatar
I have a gauge for that
Sounds normal for no intercooler. With e85 you should be fine as long as it starts to taper down like you said.
Old May 23, 2012 | 07:06 AM
reese'91's Avatar
Your running 10psi on a stock internal motor? How is that working?
Old May 23, 2012 | 07:07 AM
reese'91's Avatar
Oh yea and i think on sts website their Turbo kits run around 110* without intercooler on like 6-7 psi
Old May 23, 2012 | 09:10 AM
You say that like it something new lol. These motors will take 20 psi with heads studs and ls9 gaskets without a problem. Just gotta make sure the tune is spot on
Old May 23, 2012 | 09:24 AM
nonnieselman's Avatar
When i had my STS i had put it on in the summer i think.. Anyway i ran it without the Intercooler for about 2 days.. 6psi i saw 180* IAT and cruising i saw it hover at 125-130 which doesnt make for much power in Vacuum.
Put the intercooler on and they were ambient and only got up to 130ish after a pull.
The cooler you can keep it the safer it is. Im not sure what "limit" you should stop at.
20psi is the new 10psi..
Old May 23, 2012 | 10:16 AM
reese'91's Avatar
Ok how long are these 10psi-20psi stock motors holding up for? Because 20-30k doesnt do justice. What im trying to get at is what type of psi do run to basically not affect engine life like 180k-240k miles or is that kind of engine life out of the question at any boost
Old May 23, 2012 | 10:22 AM
IF your goin to be running 20psi all the time i dont think its goin to like it..
but theres quite a few pushing it and no ill effects yet.
Stock48, smokeshow, foose04 and a couple more are doin the 20psi thing.
Most these guys run 20# at the track and turn it down for DD.
Old May 23, 2012 | 10:23 AM
smokeshow's Avatar
Mod with training wheels
I wouldn't expect 200k out of a stock engine at 20psi, as it's a lot to ask, but I am pretty sure nobody has tried that yet.
