high compression and procharger
Fastest D1 Procharged Truck
I've been pondering putting a D1 on my LQ4 with 10.8.1 compression i dont plan on running over 12lbs and ill probably do meth just to be safe. i know ill need bigger injectors ive got 44lbs marines in it now ill probably do 60lbs.
truck is a RCSB 1500 2WD 4.10s 3600 stall
any suggestions or info would be great thanks
Should run well with that set up. I was curious about this a long while back, found that boost and compression are ok. Just have to keep it fueled well and keep the timing in check
zblee
Nov 11, 2015 12:41 AM
