high compression and procharger
Old 03-25-2013, 11:44 PM
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
Default high compression and procharger
I've been pondering putting a D1 on my LQ4 with 10.8.1 compression i dont plan on running over 12lbs and ill probably do meth just to be safe. i know ill need bigger injectors ive got 44lbs marines in it now ill probably do 60lbs.
truck is a RCSB 1500 2WD 4.10s 3600 stall
any suggestions or info would be great thanks
Old 03-25-2013, 11:47 PM
Baltimore Whore
Mangled03gmc's Avatar
Should run well with that set up. I was curious about this a long while back, found that boost and compression are ok. Just have to keep it fueled well and keep the timing in check
Old 03-25-2013, 11:51 PM
ak2007r6's Avatar
Should be a fun setup! Slap her on and let her eat!
Old 03-25-2013, 11:59 PM
8 Second Truck Club
Blown06's Avatar
do it!
Old 03-26-2013, 02:51 PM
well looks like ill start saving for a D1 then would dual walbro 255s be good enough
Old 04-04-2013, 03:58 PM
La Chochita's Avatar
Yeap...i ran dual walbro 255 and fast 60# injectors on my procharged lq4 setup @18 psi....premium unleaded of course. Never had a problem.
Old 04-04-2013, 08:34 PM
skeet's Avatar
keep the tune in check and youll be fine, this has crossed my mind quite a few times with a bigger procharger though and more compression
Old 04-05-2013, 05:10 PM
Vortec350ss's Avatar
Now thats a truck I'd love to ride in... I could see you hitting 10's with good traction off the line. Maybe I'm being too aggressive there, but Low 11's for sure.
Old 04-05-2013, 05:31 PM
xx_ED_xx's Avatar
cam change could easily help with the extra compression
Old 04-05-2013, 06:24 PM
milkey57's Avatar
My ls1 hand 10.75:1 with a p1 and 10# its was snappy and fun, go for it!
madmann26
04-29-2020 09:17 AM
zblee
11-11-2015 12:41 AM
Slammed silverado
09-28-2015 06:14 PM
sTNT971
09-26-2015 06:27 AM
MOBBN
09-22-2015 08:07 PM
Quick Reply: high compression and procharger
