Help out a dumb newbie with way too many incoherent inquisitions.
Old Oct 16, 2018 | 12:23 PM
Glockfowtay's Avatar
Originally Posted by Burnett03
Did I miss where you said what turbo you were running? You said the turbo is to large but never gave us the size of it. T4 is just the exhaust footprint, nothing more.
.96 A/R I think. Not sure what's the actual size on it, that's just what was listed.
No reason to run dual gates. Usually people run dual gates if they are twin turbo or if they running a true divided single turbo setup. You are doing neither. A 44 or 46mm will work just fine. I believe I have a 46mm and I've had boost as low as 4psi with zero creep.
I'm have a single Tial 44mm now. Plan on is just using it and not using duals.
Old Oct 16, 2018 | 01:22 PM
Burnett03's Avatar
.96 A/R is just the exhaust housing size. It doesn't tell anything about the turbo size. We need to know what the compressor and exhaust wheel size are. The single 44mm will be just fine IMO.
Old Oct 16, 2018 | 01:42 PM
98mm looks like
Compressor inducer 69mm
exducer 98mm
turbine inducer 88mm
exducer 77.5
I plan on replacing it eventually with something better. I know its gonna have bad lag especially with only 4.8l.
Old Oct 16, 2018 | 01:52 PM
Burnett03's Avatar
Originally Posted by Glockfowtay
98mm looks like
exducer 98mm
exducer 77.5
What do you consider bad lag? That turbo isn't that large really. You have a tight t4 housing which will help spool. I'm running a 75mm compressor housing on a 4.8 and the lag isn't terrible. I'm actually thinking of stepping up to a 80mm.
Old Oct 17, 2018 | 11:31 AM
kbracing96's Avatar
98mm looks like
exducer 98mm
exducer 77.5
That would be considered a 69mm turbo by most people, well, a 69/77.5 with a .96 a/r. Kind of lop sided with a large turbine. Looks like they stole the design from a diesel. It should do what you want for a 4.8 though. For hot pipes, you really should look into either KB Racing or Trick Performance. So much better than any of the Chinese stuff out there.
Old Oct 17, 2018 | 11:59 AM
for hot pipes I am running a Huron speed turbo log. The downpipe and wastegate piping is what I need. And nowhere sells that stuff separately that's not ching chang Chong origin
Thz71
Feb 12, 2016 09:14 PM
SlickSierra
Mar 8, 2013 10:14 AM
hyper
Feb 24, 2005 07:14 AM
gcooper
Feb 9, 2005 11:25 PM
FILE
Dec 21, 2003 03:58 PM
