help me spec a turbo
Old Jul 10, 2014 | 06:23 PM
MechE's Avatar
Default help me spec a turbo
I'm doing an s10 build. First time ever messing with an s10 but here goes. i have a 1998 rcsb 2wd. i have a 6.0/4l80e also with a 218/218 stock48 cam. running 3.73 gears with an 8.8 rear end. this is primarily a daily driver type build, it might see some track use. i'm still not sure if i can use a kb turbo log in the s10 yet, but i'm thinking a t4 turbo, this will be a front mount without a/c. stuck between an s475 and s480. looking to be around 15 psi primarily, might turn it up a little bit. truck will probably weigh 3600? with me in it. what would you do???
Old Jul 10, 2014 | 06:30 PM
Atomic's Avatar
I have a gauge for that
Focus on power not on boost. They are not the same. 75 will be around 700hp, 80 around 1000 at full go.
Old Jul 10, 2014 | 06:33 PM
MechE's Avatar
stock heads/truck intake, so whatever they will flow. will the 80 be too laggy? what size turbine would be best on the 80?
Old Jul 10, 2014 | 06:40 PM
gamble686's Avatar
My main concern is making the turbo fit under the hood. Losing AC will help a lot, but still. I would cross that path first. Space as side I would say s480. With a truck that light in the rear and so much power I would want the boost to hit a little later. By going a tad larger you can help prevent blowing the tires off right away. Especially in a driver this will make it more predictable on the street. A s10 will be giving you 100x more road feel than a full sized. Its fun because it means you really get to drive it right to the edge. Having a more reasonable setup down low will make it much more friendly on the street. Plus deadly from a roll.
Old Jul 10, 2014 | 06:52 PM
MechE's Avatar
yea, i do enjoy a reasonable amount of lag on the street, helps to control it alot. now i'm just shocked at how expensive 80mm's are
Chevy_King1500's Avatar
if you dont want to run a BW
my vote is PTE76mm
Old Jul 10, 2014 | 07:59 PM
oakley6575's Avatar
Put an On3 on there if the borg is to expensive. I keep hearing all these damn success stories. Now I want to put a couple of On3's on a 4.8L-6.0L and push the **** out of them.
Old Jul 10, 2014 | 08:17 PM
Atomic's Avatar
Couple of years ago before the borgs were popular precisions and garrets were $2000+, then the borgs hit and now $800 is the normal. Now the on3 brand is here and $300 is what people expect to pay.
Old Jul 14, 2014 | 11:27 AM
Blackpanther99's Avatar
A BW will do great with that setup.
smokeshow
Aug 23, 2015 08:23 PM
2500ZL1
Aug 14, 2015 12:23 AM
thewrx
Aug 12, 2015 08:28 PM
NuckenFuts
Jul 9, 2015 08:45 AM
