Help me not miss anything.
Old Jul 5, 2014 | 11:35 AM
custm2500's Avatar
Ph.D. in HUBRIS
Default Help me not miss anything.
I have been close many times to finishing my truck The HD. So nothing is set in stone about completion till it fires but I am truly the closest I have ever been. I have a manifold flipped turbo kit. 76 mm with waste gate, blow off valve, and intercooler. The engine is a stock "01 4.8 I have 60 lb. Injectors, and a Walbro 255 that will drain the fuel cell when needed.
Things I expect to need is a wide band to aid in tuning that will at least be started by Blackbear. He tuned the truck a few years ago so I will have him get me a baseline tune and attempt to streamline it on my own with either efi live.
Am I missing anything needed to get it up and runnkng?
Old Jul 5, 2014 | 11:47 AM
ZO6Ted's Avatar
I would do valve springs and boost gauge, a small cam if you can, start conservatively like 7 lbs. Lots of little extras lol. Congrats!!!
Old Jul 5, 2014 | 11:54 AM
custm2500's Avatar
Ph.D. in HUBRIS
I have some valve springs. I was going to cam my Denali and use them in it but I might just stick to getting The HD done since money always runs out before I get on project finished let alone two!
Do others agree on springs? The engine has 160,000 on it and I won't be spinning past 6000 I don't think.
Also just to confirm the truck has an 80e so I need the flex plate of the stock 6.0 correct?
Old Jul 5, 2014 | 12:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Just my opinion but I would still do valve springs. The added boost will likely make the factory springs creep open and may add to causing valve float in the upper RPM range.
Old Jul 5, 2014 | 03:13 PM
custm2500's Avatar
Ph.D. in HUBRIS
Well I have them and will put them in the 4.8.
Old Jul 6, 2014 | 12:18 AM
custm2500's Avatar
Ph.D. in HUBRIS
The truck has remote oil cooler. Can I use the lines to feed and return oil for the turbo?
Old Jul 6, 2014 | 12:28 AM
MustangPunk's Avatar
feed yes, I know I've seen adapters somewhere... return I do not believe, being it's under pressure... just drain back to oil pan from turbo like normal
Old Jul 6, 2014 | 07:12 AM
custm2500's Avatar
Ph.D. in HUBRIS
The truck has a factory adapter. I will just T the line.
I have seen some have a bung added to the pan. Is that the only way or is there a plug that can be removed somewhere on the engine?
Old Jul 6, 2014 | 08:13 AM
silver-mod-o's Avatar
Hunt&Fisherator
You seriously must not be faimiliar with these engines at all.... Still.....
Just like the dozens of others, you'll have to drill the pan (above the operating oil level) and return it there. Unless you want to run a scavenge pump and return it into a valve cover ghetto STS style.
Anyone else want to start a pool on how long this engine lasts?
Old Jul 6, 2014 | 06:59 PM
custm2500's Avatar
Ph.D. in HUBRIS
I was just confirming that on the heavy duty oil cooling set up there wasn't anything extra. I have a guy who can weld a bung in my oil pan no problem. Would it be any benefit to keep the factory oil cooler in line before the turbo?
Most people who turbo don't do it to a 2500 chassis and I don't believe the oil coolers are common on the 1500 trucks. Sorry I don't know everything. Like anything I do I try to learn everything I can.
As for going in the valve cover that sounds like a bad idea.
