Help ID this turbo
Old Dec 25, 2011 | 04:08 PM
tarinitup's Avatar
9 Second Truck Club
Default Help ID this turbo
I was given a t6 Garrett turbo but I have no idea of its specs. I assume it was originally for diesel because of the waste gate it has but I'm hoping I can change turbine housing and adapt it to my kit to see how it does. Wheel diameter is smaller than my 91 mm, it has .60ar stamped on front cover and 1.28ar on hot side. Looked up online and it kinda looks like a Garrett 4202 with diff hot side but I'm no expert. Here are some pics.
Old Dec 25, 2011 | 04:12 PM
chevybowtie's Avatar
Yep...Its either a GTA4294 or a GTA4202. The 94 has a inducer of 70mm and exducer of 94mm and the 02 has a inducer of 72mm and exducer of 102mm.
Old Dec 25, 2011 | 04:17 PM
tarinitup's Avatar
9 Second Truck Club
so take it apart and measure the wheel for positive ID?
Old Dec 25, 2011 | 04:19 PM
yea or does it still have the tag on the cartridge? Should be a green metal tag from Garrett. Just need the part number which should be the second one down.
Old Dec 25, 2011 | 04:40 PM
tarinitup's Avatar
9 Second Truck Club
Old Dec 25, 2011 | 07:00 PM
kbracing96's Avatar
Do you have calipers? Measure the inlet, small size of the compressor wheel and the same with the turbine. That will tell you a lot about what the turbo will support.
Old Dec 25, 2011 | 07:08 PM
tarinitup's Avatar
9 Second Truck Club
Don't have calipers but I'll borrow some and post up.
Old Dec 25, 2011 | 07:10 PM
This may sound sick but wrong end. The turbine wheels on both the gt4294 and gt4202 are the same. Actually that is the reason why they call them GT's is the design of the wheel. To go on...The compressor wheel is what you'll need to measure to see what one you have. Any which way. These turbo's would be great on a stock 5.3. Would make around 550-600rwhp. The turbine housing is the only thing that makes these things undesirable since the cost is high.
Old Dec 25, 2011 | 07:30 PM
99LsSilverado's Avatar
I might be going out on a limb is the turbo is for a Detroit Diesel. Only because of the two arrow circle on the outlet of the cold side of the turbo.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
