help with head choice
Old Feb 4, 2013 | 07:15 AM
kush killer's Avatar
Default help with head choice
opinions on running some 241 heads on a 5.3 oem gapped rings, and ls9 gaskets,
i used a calculator and it put it around 8.6:1
willbe running a tu1 cam
76mm turbo
e85
stock short block
long term goal is 700rwhp
Old Feb 4, 2013 | 09:53 AM
I would just run stock 5.3 heads. 8.6 would feel like a dog out of boost. That goal is very attainable with stock heads with good springs
Old Feb 4, 2013 | 09:57 AM
Ferocity02's Avatar
What he said.
Old Feb 4, 2013 | 12:19 PM
cool thanks guys, thats waht i was affraid of, i have these 241 in the shop but my 862's are the "notch" style
ive got BTR dual platinum series springs
Old Feb 4, 2013 | 12:21 PM
Ferocity02's Avatar
You could mill the 241's but that would reduce the deck thickess some, not a huge deal unless you are going to be pushing LOTS of boost. Or you could pick up a set of non-notch factory heads with the correct CC volume. What year is your 5.3L?
Old Feb 4, 2013 | 12:27 PM
chevyboy.520's Avatar
if you want to run more then 15 psi and keeping upping the boost. which is very addictive! i would run the 241. if you are staying with low boost get a set of stock 5.3 heads that are not notched! im running about 8.7 -1 compression and out of boost isnt too bad. normal driving is good. but im also running 19-21 psi lol. that turbo on e85 will like more boost.
good luck with the build.
BTW, im running a 06 shortblock, stock rods, stock flat top pistons out of a 08' 5.3, and 317 heads and ls9 head gaskets.
last time we were tuning, i was on 18 psi, 91 pump gas and no knock retard. im running 21 now with meth.
Old Feb 4, 2013 | 12:47 PM
the motor is a 2000 and yes i plan to run more than 15#'s
thats why i figured the 241 would be ideal, truck ownt get alot of track time, and when it does its only the 1/8 mile..
Old Feb 4, 2013 | 12:55 PM
do you already have the 241's sitting on the shelf?
Old Feb 4, 2013 | 02:12 PM
gamble686's Avatar
I would say find some 243/799s. Much better flow same compression and about the same price. You can find complete 243s for about $300 now thanks to them being stock on gen IV 4.8/5.3 motors. I believe that is what Mitch is running in his 10sec turbo 5.3 ecsb.
