help with head choice
Old Sep 24, 2012 | 12:20 PM
kush killer's Avatar
Default help with head choice
gettin ready to start my lm7 turbo build.. need help decideing which heads to run, i have 862's right now, but have access to som 853's, 241's 799's... was also recommended 242's or 243's.. whats the best suited head to run? iknow the 853 would lower compression
Old Sep 24, 2012 | 12:54 PM
Ferocity02's Avatar
What are your goals power wise? Budget?
Old Sep 24, 2012 | 01:11 PM
03regcab sierra's Avatar
Run the 799s if u can get em cheap. Lower compression and better flow is always good on a turbo build
Old Sep 24, 2012 | 01:17 PM
Ferocity02's Avatar
I will be using milled 799's, got a new pair for $460 shipped, plus milling work at WCCH to get back to 9.5 SCR.
But if your power goals are modest, stock 862's are fine.
Old Sep 24, 2012 | 01:59 PM
chevrolet all the way's Avatar
Try to get 799s. Also im running milled 317s and happy with them you can find them cheap for the power gains! certainly worth the money imo
Old Sep 24, 2012 | 08:53 PM
im tryin to squeeze every last drop out of her for as cheap as possible. i can pick up the 799's for 300
Old Sep 24, 2012 | 09:40 PM
swift700's Avatar
799's or 243's would be perfect on a budget.
Old Sep 25, 2012 | 12:23 PM
what about some 805's?
Old Sep 25, 2012 | 12:42 PM
Ferocity02's Avatar
You mean 806? I've never heard of 805. I think 806 are the perimeter bolt heads found on '98 f-bodies. Not very desirable and are a negligible improvement over stock 5.3 heads, would need to be milled also for stock compression.
Old Sep 25, 2012 | 05:07 PM
sorry yeah was suppose to say 806's.. looks like i jsut roll some 799's thanks guys
axekick
Sep 7, 2015 07:01 PM
JordanH
Aug 8, 2015 07:59 PM
sTNT971
Aug 7, 2015 09:05 AM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
