HELP! fuel pressure/ 9psi max boost b4 130% duty cycle.
Old Oct 1, 2013 | 12:03 PM
Sweetser54's Avatar
Default HELP! fuel pressure/ 9psi max boost bc factory wiring won't feed pump?
I have an 03 silverado 6.0 78 mm turbo. 60 lb injectors , walbro 340 lph in the tank. I am currently running 9 lbs of boost. when i try and turn the boost up i cant bc its goin to 130 % duty cycle i think its bc the fuel pressure drop when i try and add more boost. stock lines. would running a 10 guage hot wire kit to the tank solve this problem completly or will i have to run a return line to the tank and put an boost reference FPR on the fuel rail?
any advice would really help. thanks
Old Oct 1, 2013 | 12:11 PM
Ferocity02's Avatar
The obvious question would be what happens to your fuel pressure in boost? 60# injectors at 9psi I don't think you should be anywhere near 130% DC.
Old Oct 1, 2013 | 12:41 PM
Chevy_King1500's Avatar
60# at what psi?
mine are 3bar 60# and im at 55% at 7psi
Old Oct 1, 2013 | 12:47 PM
Ferocity02's Avatar
Originally Posted by Chevy_King1500
60# at what psi?
I have the same injectors, but my DC is lower than yours at that boost, 40-45% maybe. I am injecting methanol though.
Old Oct 1, 2013 | 12:55 PM
Sweetser54's Avatar
the injectors r working harder bc fuel pressure drops alot at wot in boost. 9 psi is as high as i can go and its at 73 % duty cycle there. any higher on the boost and it goes to 130% at 11 psi. hot wire kit 10 guage to the pump for more volts? will this solve the problem or will i have to get a boost reference regulator and run a return line to the tank and mount regulator on the fuel rail?
Old Oct 1, 2013 | 12:58 PM
Sweetser54's Avatar
im running stock wires to and in the tank. stock fuel lines.
Old Oct 1, 2013 | 01:27 PM
Vortec350ss's Avatar
Are you running on E85? Whats your A/F ratio? The fuel pressure drops bc the injectors are pushing through 130% of their 'capability', which is more than the pumps capability.
Old Oct 1, 2013 | 02:04 PM
Ferocity02's Avatar
Definitely run a thicker wire to the pump, that's a large pump for the stock wiring.
Old Oct 1, 2013 | 04:54 PM
Sweetser54's Avatar
ferocity02 thank you for your advice. i think u r the only one that actually knows what im saying. so u think this will let the pump work to it capability and then i wont have this problem anymore. i should be able to get to 550 rwhp easily on my set up. im just trying to set the boost at 12psi and i was confused bc i know the pump and injectors are more than capable of that.
Old Oct 1, 2013 | 04:55 PM
Sweetser54's Avatar
im on pump gas
