Help with cam pic for 6.0 Chevrolet
Old May 21, 2019 | 10:36 PM
Chevyguy327's Avatar
Default Help with cam pic for 6.0 Chevrolet
Any help is greatly appreciated driving me nuts trying to find a cam I have 02 Silverado 6.0 317 heads with a procharger 44 pound injectors p1s ProCharger Hedman shorty headers I live in commiefornia I just want a little more horsepower every website I get on wants me to put a stall converter or not live where I do all suggestions helpful please do remember it's f****** California
Old May 21, 2019 | 10:52 PM
FFDP's Avatar
Soooo, you don't want to run a stall converter??
Or do you?
If not, don't overthink this stuff. All the information is out there on camshafts that work with stock stalls and shouldn't ruin your life because you live in a stupid state. Stay small but still larger than stock. Texas speed and BTR both offer camshafts slightly larger than stock. They won't lope much and should keep things pretty tame to help pass emissions with good cat converters.
Like this.
https://www.briantooleyracing.com/ca...k-stage-i-cam/
Or their new V2 on that same camshaft.
https://www.briantooleyracing.com/ca...212-218-111-0/
Old May 21, 2019 | 11:35 PM
Default Thanks for the reply
Everytime I try to look at cams, they want to sell me pushrods, valve springs, and all this other stuff. I'm trying to budget. Get away with max horsepower for minimum price.
Old May 21, 2019 | 11:40 PM
I'm fine with stall converter, but didn't intend to spend 1300 for cam with converter.
Old May 22, 2019 | 06:01 AM
05GMC4.8's Avatar
Ls2 or ls3 factory cam, other wise springs and push rods are required. And even with those. Cams new factory springs are needed.
Old May 22, 2019 | 05:19 PM
FFDP's Avatar
Even with the cams I posted, you can get away with the full swap for probably under $600 total.
You only need LS6 valve springs which are cheap and to measure your pushrods. You may or may not need them and even if you do, new push rods are not a lot of money.
Old May 22, 2019 | 11:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Brian tooley also has his own line of LS6 type spring that will save about $10 over the GM springs. BTR .560" LS6 BEEHIVE VALVE SPRINGS
TSP and BTR have Push rod sets for $94
Cam is $389 from TSP or BTR
Old May 23, 2019 | 06:33 AM
madmann26's Avatar
To add to @1FastBrick notes above, @WS6store.com can do cam/springs/pushrods for under $700.
I'm sure Mike will weigh in an offer you some great options.
Old May 23, 2019 | 01:16 PM
03sierraslt's Avatar
Texas Speed also has complete kits for under $700
Offroadunleashed
Jul 20, 2015 02:25 PM
parish8
72
Dec 4, 2005 12:22 AM
Gallitin
Jul 22, 2004 07:11 PM
slik98z
Jul 19, 2004 08:43 AM
