heads for maggie
Old Sep 10, 2008 | 09:51 PM
terravast4's Avatar
Default heads for maggie
I have finally collected almost all the parts for my next mod: 90mm tb and j-tube, DR. X adapter, 60# injectors, lingenfelter 100mm maf, recently purchased gt2-3 cam. My last purchase is some good heads to complete the package. I am leaning to just a good set of ported 5.3 heads but my question is what are the benefits of using a set of ported ls6 headson my 5.3 with the maggie? What will I lose/gain from the lower compression ratio of the ls6 heads. Anyone tried this or have any thoughts on this? Thanks.
Old Sep 10, 2008 | 09:59 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
you will be able to turn up the boost a bit more without having to give up as much timing.
Old Sep 10, 2008 | 10:07 PM
terravast4's Avatar
do you think I will run a little more efficient with the ls6 heads. I think the maggie is maxed out with the 2.8 pulley and that is my main concern.
Old Sep 10, 2008 | 10:15 PM
trever1t's Avatar
yeah, mybad, that is a small pulley. How many lbs. are you makng? Your running the stock heads now?
Old Sep 10, 2008 | 10:45 PM
terravast4's Avatar
stock heads and about 9#
Old Sep 10, 2008 | 10:56 PM
Stoichiometric's Avatar
That is not much boost for your pulley size. I would wait and see what the 90mm does before changing the heads.
Old Sep 10, 2008 | 11:08 PM
terravast4's Avatar
I am doing the cam swap so while I am there gonna do the heads.
Old Sep 10, 2008 | 11:20 PM
To answer your original question; I would not lower the compression. I would keep the compression between 9.5 and 10:1. If you plan to spray keep it at 9.5:1.
Old Sep 11, 2008 | 01:04 AM
NORCAL TBSS's Avatar
Restricted User
i have the trick flow 235 70cc for my maggie 122 the heads are bad ***.
Old Sep 11, 2008 | 07:07 AM
terravast4's Avatar
yes, but you have a 6.o I have a 5.3.
