headers/heat wrap.... what is the "best" way to do it?
Old Jan 22, 2011 | 12:01 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Default headers/heat wrap.... what is the "best" way to do it?
what are you securing it with and what steps are you taking to install it..
i want to start on mine today!
Old Jan 22, 2011 | 12:05 PM
2004SSS's Avatar
stainless steel safety wire. invest in some safety wire pliers now
Old Jan 22, 2011 | 12:08 PM
OK... only one question
what is that and were do i get it
i do electronics for a living
Old Jan 22, 2011 | 12:10 PM
2004SSS's Avatar
these
http://www.google.com/products/catal...d=0CHIQ8wIwAQ#
and a nice roll of stainelss safety wire. you just pull on the pliers and it spins the safety wire making it clamp the wrap.
Old Jan 22, 2011 | 12:15 PM
these
O.... so basically... electric fence wire (to a point)
just a wire that is strong and will not rust through and fall apart...correct..
Old Jan 22, 2011 | 12:54 PM
05stepside's Avatar
the shop that installed my kit told me that they soaked the wrap in water so could stretch it out and make for a tighter fit.
Old Jan 22, 2011 | 12:57 PM
Do you have to spray anything on the raw pipe...or on the wrap after it is installed?
The water sounds legit but has anyone else done it?
Old Jan 22, 2011 | 01:11 PM
Atomic's Avatar
I have a gauge for that
I used big worm clamps to hold then ends together, I think it looks pretty good.
If you soak the wrap, it will make a huge mess but does make it easier to wrap tight.
Old Jan 22, 2011 | 01:20 PM
schino's Avatar
the stuff i used said to wet it, they may all be like that. i used dei i believe. and like said use safety wire, the tool is a bit pricey but its nice to have around.
Old Jan 22, 2011 | 02:03 PM
we... i ran out and i also want to get some worm clamps are something that looks better than the wire holding it... but here is what i got done so far... this **** is not easy to do by yourself...lol
