Has anyone bought from catchcans.com?
Old Oct 7, 2012 | 09:09 PM
iregret's Avatar
Charlie Murphy!
Default Has anyone bought from catchcans.com?
I've been researching catchcans. I'm going to be going turbo probably next spring. I'm collecting all the parts I can think of.
I came across catchcans.com. Anyone bought from them?
Is 94.00 a reasonable price?
All the pictures show them mounted on the left side. Thought that was unusual.
Last edited by 03sierraslt; Oct 7, 2012 at 10:09 PM. Reason: Non sponsor link removed
Old Oct 7, 2012 | 09:12 PM
black00chev's Avatar
Slowest turbo build ever!
This is where I got my catch can from. Got it through a group purchase so I did not deal with the site directly. Been very happy with it. Although I think I need to re-seal the threads on the barb fittings where they go into the can.
Here is when I first installed it. Engine bay has since been cleaned.
Old Oct 7, 2012 | 09:19 PM
chevyboy.520's Avatar
I know several ppl that run those. I'll be running one soon
Old Oct 7, 2012 | 09:59 PM
lglowe's Avatar
I highly recommend a rx dual valve catch can I have one and its sweet. It's made for boost applications
Old Oct 7, 2012 | 10:20 PM
Do you think this one would not be good for boost, even if I have the check-valve style PCV in the valve cover?
Old Oct 7, 2012 | 10:28 PM
slammedsilvy's Avatar
Those are the Mike Norris cans. I run one, I picked it up from Scoggin Dickey though. Most are shown on the passenger side because Corvettes and Camaros have the PCV on that side.
Old Oct 8, 2012 | 12:38 AM
iregret's Avatar
Charlie Murphy!
Here's a link to the RX ones.
Revextreme.com
I would imagine that if you were to put a check valve inline with the catchcans.com one, it would effectively be the same.
So, what check valve are you guys running?
Last edited by 03sierraslt; Oct 8, 2012 at 08:07 AM. Reason: Non sponsor link removed
Old Oct 8, 2012 | 01:09 AM
Just ordered a blue catch can. I run a one way check valve in between catch can and intake. I got the one-way check valve from local speed shop.
Old Oct 8, 2012 | 04:32 AM
iregret's Avatar
Charlie Murphy!
Well I decided to go with the black one from catchcans. I'm eager to get it installed on my stock 5.3L. I consume about a quart of oil every 5000 mile oil change. I run Mobil 1. It'll be interesting to see how much oil I recoup.
I'll be doing a 6.0L swap when I go turbo. I'll have to do some research on check valves now. I don't have a local speed shop so I'll have to mail order. Unless you can get them from Napa or Autozone.
Thanks fellas.
Last edited by dewmanshu; Oct 8, 2012 at 07:24 AM. Reason: sounds silly, but just removing the .com linking.
Old Oct 8, 2012 | 07:23 AM
RibeiroBJJ's Avatar
Praise The Lowered
Originally Posted by iregret
Well I decided to go with the black one from catchcans.com. I'm eager to get it installed on my stock 5.3L. I consume about a quart of oil every 5000 mile oil change. I run Mobil 1. It'll be interesting to see how much oil I recoup.
Thanks fellas.
I run one from CC.com as well, It seems to work great. And you can get a pcv "check valve" style from a 90's SC'd Thunderbird...Its a direct fit
