Guys with nitrous and FI step in
Old Apr 22, 2010 | 09:26 PM
1BADAZZSS's Avatar
Default Guys with nitrous and FI step in
I was wanting to know how everyone was jetting there nitrous kits on a boosted app. How exatly do you determine the fuel jet. My truck has 58psi FP @ 0vac. Now when it goes up into boost my FP jumps to 72psi when the 2nd pump kicks on and thats on 12#. Question restated is what FP do I base my fuel jet off of, 58 or 72?
Old Apr 23, 2010 | 01:31 PM
BigKID's Avatar
You would base your calculations on the referenced WOT fuel pressure as that is the pressure the jet will be seeing.
Old Apr 23, 2010 | 02:00 PM
nonnieselman's Avatar
I used the jets for 60psi.. it richened up at higher boost, which is sorta good it went from 11.2 to 11.0 on the kit..
You cant do a COS5 can ya? That would be your ticket..
You planning on spraying it out of the hole or out of the hole to the traps?
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
