Guys with 42/44#'s and 255 in-tank...
Old Feb 13, 2011 | 09:34 AM
kazfan30's Avatar
Default Guys with 42/44#'s and 255 in-tank...
I have searched till im blue in the face, and even posted something on this a few months back, but i would like to know how far you went on this fuel setup.... Hp/tq numbers. I would like 60's later but i have 44's now and a 255 and want to use them as far as it will go.. I have read up to 500rwhp which is great!! But some guys are maxing them out a little over 400rwhp So forgive my ignorance but how come such a broad range of numbers till "maxed" out? Thanks for replies guys
Old Feb 13, 2011 | 09:39 AM
slowec's Avatar
Not sure about dyno numbers , but all three front mounts in my area are running that set up and we are all around 100%. If you logged it, I bet you are maxed out now!
Old Feb 13, 2011 | 11:30 AM
smokeshow's Avatar
Mod with training wheels
I'm over 500rwhp with 42s, though I do run meth as well. Not to say you should, but it can be done. It's all in the tune.
Old Feb 13, 2011 | 12:04 PM
kazfan30's Avatar
Yeah kyle also said I should be ok as well to 500 which will suit me fine for my dd. I also plan on running meth as well this summer... And get some 60s when I go 10 psi later
Old Feb 13, 2011 | 01:55 PM
CashDudeHomie's Avatar
I have the 42# marine? that come with the Radix, and they are 100% duty at 4900 RPMs. The Walbro 255 pump is still pushing strong. So the injectors will max out first.
Old Feb 13, 2011 | 03:37 PM
kazfan30's Avatar
Any dyno numbers cashdudehomie?
Old Feb 13, 2011 | 03:55 PM
Mangled03gmc's Avatar
Baltimore Whore
Time for bigger injectors.. The 255 pumps can support more then 500 hp.. You could give the meth a try, but I would swap to new injectors. I am running 60lbrs, have seen as high as 78-80% IDC's so i would think they are plenty for you..
Old Feb 13, 2011 | 05:03 PM
kazfan30's Avatar
man...... This sucks lol. I so dont have 450 dollars for new injectors and a retune.. Pay to play lol,but abiut paid out.
Old Feb 13, 2011 | 05:28 PM
Atomic's Avatar
I have a gauge for that
The big variance is from the huge range of drivetrain efficiencies and dyno calibrations.
An engine that makes 500rwhp on a truck with an 80e, 14b, 4wd, and 40" tires is putting out a lot more fly wheel horsepower than a truck with 500rwhp with a 60e,10bolt, and 29" tires. This is an exaggeration, but you get the point. Also dynojets for instance typically dyno higher than say a mustang dyno.
Old Feb 13, 2011 | 05:50 PM
blue0453's Avatar
Im runn ing high flow walbro, 42#rs, and at 7psi Im at 105% duty cycle. Gonna get some 60s from FIC plug and play for $480
