Guess my HP
Old Dec 4, 2024 | 08:04 PM
BIG_KID's Avatar
Default Guess my HP
2004 5.3L
M112 supercharger (3” pulley)
baby cam & springs (212/218 .550/.550 112+2)
AWD conversion
everything else is stock
crank & wheel HP please…
Old Dec 5, 2024 | 03:15 AM
smokinlmm's Avatar
Flex fuel truck? How much boost?
Old Dec 5, 2024 | 07:36 AM
terravast4's Avatar
390 at the tires
Old Dec 5, 2024 | 12:19 PM
Fullpower's Avatar
Originally Posted by terravast4
390 at the tires
Good Guess.
If OP gave some more tune parameters, we'd narrow it our guesstimate down:
Injector flow rate, duty cycle, spark advance vs airmass table, and describe the exhaust system in some detail.
Has the factory stock 2-5/8 ID Cat to Head pipe flange been modified or REMOVED ? That restriction alone will cork you hard above 5000 rpm
Old Dec 5, 2024 | 07:18 PM
BIG_KID's Avatar
for now pump gas
hopefully 9-10 lbs
Old Dec 6, 2024 | 03:43 AM
smokinlmm's Avatar
Around 425 rwhp if your tuner maxes out injector.
Old Dec 6, 2024 | 02:54 PM
BIG_KID's Avatar
what if I got bigger injectors ?
Old Dec 6, 2024 | 03:10 PM
Fullpower's Avatar
My magnuson shipped with GM 8.1 L Marine injectors, I think they flow about 42# hr.
I have same cam as you: 212/218 .550" Low Lift on a 4.8LS. 3.2" pulley on TVS1900 makes 11 PSI... My 2 limiting factors are the STOCK airbox and 3" Gibson full exhaust with shorty headers. Pretty sure that 3" pipe and MUFFLER strangles me at or a hair under 500 flywheel HP.
As I said in earlier post, IF you are running stock exhaust, that 2-5/8" INSIDE restriction is going to flatten your power above 4800 rpm.
Old Dec 6, 2024 | 03:34 PM
BIG_KID's Avatar
Mine has the 48lb injectors also. My tuner threw out maybe 60lb incase we need to go to E85. I’m running 3” single exhaust as of now
Old Dec 6, 2024 | 06:11 PM
RDF1's Avatar
DuNnO
5 Year Member
Atleast 350hp..
