Got a new toy...
Old Mar 30, 2012 | 09:09 PM
Atomic's Avatar
I have a gauge for that
Default Got a new toy...
BW S400SX3 with a 76mm compressor and the "J" wheel 81/87mm
Old Mar 30, 2012 | 09:16 PM
chevybowtie's Avatar
We need a little size comparison. Maybe against a set of *****.
Old Mar 30, 2012 | 09:25 PM
BlackGMC's Avatar
Resident Retard
Geez i doubt that thing will fit in the bed much less under the hood
Old Mar 30, 2012 | 09:39 PM
milkey57's Avatar
That looks huge, and I don't want to hear. "that's what she said last night"
Old Mar 30, 2012 | 11:32 PM
smokeshow's Avatar
Mod with training wheels
Frame size should be comparable to the PT88, yeah?
Old Mar 31, 2012 | 01:11 AM
chevyboy.520's Avatar
I like your new toy!
Old Mar 31, 2012 | 06:22 AM
TIM Z's Avatar
11 sec. Truck Mod
Wow Richard that is baddass, bet its gonna sound like one of the 10.5 outlaw cars!!
So tell me about what ins & outs of this " J" wheel.
How much boost is your setup going to be running?
Vids for sure or else!!!!
Old Mar 31, 2012 | 09:18 AM
Atomic's Avatar
Frame size is still T4, and the exhaust housing is basically the same as the PT88, so everything should bolt up fine. Oil feed and drain are also the same. The cover, on the other hand, is a lot bigger, probably 50% larger in diameter.
The compressor wheel is 76mm, and the turbine wheel is 81/87 versus the 94mm of the pt88. The guys at BW say this wheel will flow just as much but respond much better.
This turbo *may* make slightly less peak power than the pt88 but it should be much more controllable than the pt88 and spool much, much faster. The guy I bought it from put my engine specs into the BW program to see how it would respond and it said should have full boost by 2500rpm and not max out until 6400rpm ish. Im not looking for max drag racing power, just something fun to drive, and the pt88 wasnt that fun.
Reed at Work turbochargers in Birmingham is who I bought it from. He is one of the most knowledgeable turbo guys I have ever talked to, and spent probably an hour on the phone with me answering questions and talking before I ever said I would buy something. I highly recommend him if anyone is in the market for a new turbo.
He mentioned if the current 1.10 AR exhaust housing is too responsive he would be happy to switch it out for a 1.25AR. Also if the compressor ends up being too small then we could change it up to the 80mm compressor. Customer service doesn't get any better than that.
Boost goal is still the same, 16-18psi.
Old Mar 31, 2012 | 09:26 AM
sprayedenali's Avatar
Reed and work turbos kick ***!!! No doubt about it...
I'm really excited to see how this thing works out for you.
Old Mar 31, 2012 | 11:07 AM
smokeshow's Avatar
I have a feeling its gonna be fun as ****.
