Got my D-1sc, what else do I need
Old May 8, 2006 | 09:22 PM
Blown06's Avatar
8 Second Truck Club
Default Got my D-1sc, what else do I need
I just received my d1 tuner kit from procharger with 3-core IC. What will I need fuel wise to support this on a stock truck with just a cat back exhaust.
Injectors? Size? Where to get them? Do I need to do anything fuel pump wise? Booster pump? What brand? Also need recommendations on gauges.
If down the road I have the need to step it up even more (more boost, cam, displacement, ect.) What am I going to do with this returnless fuel system? What are the limits with the stock pump w/ a booster? I really don't want to destroy the functionality of the pump bucket. Is Parishes truck a return style? If so what do you recommend.
Also any recommendations for the install? Anything to look for that I may not be expecting?
Thanks ahead for the help.
Old May 9, 2006 | 02:34 PM
Bad_Apple's Avatar
I would go ahead and slap a set 04 44lbs inj. and get a good tune. You will always have some bugs to work out, but you will definitley need some 44lbs and a good tune. And go ahead and get started beffeing that tranny up.
Old May 9, 2006 | 04:20 PM
zippy's Avatar
You're going to want at least a 50lb hr injector. I'd recomend starting off with some 42lb SVO's (also called lightning injectors). You're also going to want either a Magnavolt or Walbro intank pump upgrade. As for gauges, I recomend a boost gauge, Aeroforce Interceptor, and a wideband gauge.
phantom-09
May 20, 2011 05:01 PM
Rick_Vor
Nov 18, 2010 09:33 PM
jetttstream
Nov 1, 2010 03:14 PM
phantom-09
Dec 2, 2009 11:04 AM
phantom-09
Dec 2, 2009 10:20 AM
