got er done....
Old May 17, 2006 | 04:39 PM
Allgonoshow's Avatar
Smile got er done....
Finally got my Radix installed.
For those considering this kit I gotta say it is absolutely complete and
a very straight foward install. Took 6 hrs in shop with a hoist. You wouldn't need a hoist except to do the fuel pump [that only took 45 min to do]
Only thing I didn't do is the boost gauge, I'll do that tomorrow.
Flashed up first time, no leaks or codes. I was also able to use my K/N open element air box with the Radix inlet tube, minor mods reguired
Took it for a drive with a scanner to check stuff,
no knock, timing at 16 deg wot, 30+ deg cruising. o2's around 850 so I'd say all is well.
Didn't beat on too hard yet but I will soon, shift kit and vette servo going in as soon as I have time.
I must say the tune that comes with it must have some tm pulled as the 1-2 shift is a lot better.
Anyway, gotta go for a drive.
Dave
Old May 17, 2006 | 04:52 PM
03sierraslt's Avatar
Good deal man, were your 02 readings 850 at Wide open near the shift point?
Old May 17, 2006 | 05:06 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sweet! Congrats on the install!
Old May 17, 2006 | 06:05 PM
XLR8NSS's Avatar
Adkoonerstrator
WOOHOO!! Glad you got it installed Dave.
Old May 17, 2006 | 06:20 PM
thanx guys
i was driving and bud was watching scanner, so not sure exactly what rpm range the 02's were at, but it was wot.
what should it be?
it will be a while before i get a wide band so o2's and reading plugs is all i can watch for afr.
man this thing makes some awesome sounds too...
Old May 17, 2006 | 06:41 PM
TIM Z's Avatar
11 sec. Truck Mod
you want o2 readings in the 920-930 range at WOT. thats safe . I wouldnt get on it hard with readings in the 850 range. but these are guide lines for my setup but i think they should be about the same for your maggie, BTW congrats on getting blown!
Old May 17, 2006 | 06:55 PM
i'll double check those o2 readings,
so 920-930 near top of rpm range @wot?
Do you have a dyno or mail-order tune?
yeah, nothing beats getting blown
Old May 17, 2006 | 06:59 PM
TIM Z's Avatar
11 sec. Truck Mod
YES ,920-930 at W.O.T .i have a mail order tune ( NELSON). Allen has really worked with me to get me dialed in. I just relay my fuel and timing values along with some others to him and He's done a great job of getting my truck Running sweet. I would also love to get it on the dyno this summer and see what kinda smoke its puttin out.
Old May 17, 2006 | 07:45 PM
HDMLNIUM's Avatar
Glad to see that you are happy with the kit, and you had no problems with the install. I ordered one a couple weeks ago and it should be here next Tuesday. So next weekend if everything goes right I will have my Radix in and be blown as well..lol
Bill
Old May 17, 2006 | 08:46 PM
parish8's Avatar
single digit dreamer
boost is adictive. , have fun with it.
