Good Cam for force induction
Old Jul 14, 2008 | 05:03 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by Wilde Racing
not when the intake valves have got boost pressure on them...
He didn't ask about the springs. I would never run stock springs on anything with boost. 130~145lbs on seat, 300+ open minimum with boost and .550'' ish lift. With the big valve in those L92 heads he is going to need good springs, thats a lot more area for the boost to push on.
Old Jul 14, 2008 | 10:24 PM
UAE's Avatar
UAE
Thanks guys for the input.
Old Jul 14, 2008 | 10:30 PM
supersub's Avatar
is that 6.2 vvt?
Old Jul 15, 2008 | 12:39 AM
UAE's Avatar
UAE
It is Denali 2007 6.2
Old Jul 15, 2008 | 03:25 AM
rclnc's Avatar
You might want to look at the Lingenfelter GT2-3 cam..
Old Jul 17, 2008 | 02:49 AM
Y2KLimited's Avatar
Originally Posted by supersub
is that 6.2 vvt?
I know my suburban is........not too sure on the 6.2's but you bring up a great point that needs to be researched as well. We had a few tuning headaches with it because I didn't have a clue nor did my buddies at the shop, did the normal thing backing off timing adn the thing kept on pinging....didn't realize it had a whole other table and page going on different from vettes of course these new trucks are supposed to have some really cool features in the computers that blow everything previous away, but thats technology for ya.
Old Jul 17, 2008 | 07:12 PM
Slowhawk's Avatar
LS1Tech Sponsor
With the heads you have none of the cams listed above would be good.
Last edited by BlownChevy; Jul 17, 2008 at 11:43 PM. Reason: Stop posting your sig........
Old Jul 17, 2008 | 07:40 PM
leftcoast32's Avatar
FormerVendor
There are several of us on the board running the L92's with aftermarket cams. You really need to look at the flow numbers for the heads and design the cam around the flow and induction package you are running.
Old Aug 13, 2008 | 04:17 PM
UAE's Avatar
UAE
is that 6.2 vvt?
Yes it is.
I just got this email from lignenfelter
The 6.2 L engine uses a camshaft phaser assembly that will not work with our GT2-3 camshaft. You would need to change front cover, lifters if it has the cylinder deactivation, timing set and the software to change camshafts so the results would most likely not be worth the expense.
Thank you,
Raggedz71
Jul 29, 2016 10:20 AM
Silveradorst07
28
Apr 3, 2016 02:56 AM
Silveradorst07
Dec 31, 2015 12:04 AM
Cm_gmt800
Aug 3, 2015 09:13 PM
black6spdz
Jul 16, 2015 01:32 AM
