Going turbo... Few Questions!!!
Old Aug 14, 2006 | 05:37 PM
Banned
Default Going turbo... Few Questions!!!
Alright guys...
Ive had twin rear mounts on this truck...
2003- 5.3 ext...
Ok.. I have a few questions..
Does anyone make turbo manifolds for front mount twins for these engines....?
For oil supply the return is gravity fed... But is the inlet pressurized by the crank case pressure??
Thanks in advance!!
Old Aug 15, 2006 | 08:24 AM
ktmrider's Avatar
Parish and CMotorsports are the folks to talk to. I saw the TT Toronado that Jay Leno had built using an LS1 engine, seems like they flipped some stock truck manifolds and welded on a mounting flange. It's probably not so easy as it sounds tho!
Here's the thread link https://www.performancetrucks.net/fo...d.php?t=369970
Old Aug 15, 2006 | 08:28 AM
duwem's Avatar
Banks twin turbo kit would be a good one to look at
Old Aug 15, 2006 | 09:23 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
CMS closed its doors.
Old Aug 15, 2006 | 10:19 AM
BlownChevy's Avatar
blownerator
25 Year Member
make your own! There are a few guys on here that have.
Old Aug 15, 2006 | 10:24 AM
Allgonoshow's Avatar
i believe i read somewhere that the 5.3 grandprix or impala manifolds work on trucks when flipped, the manifold outlet ends up in a better position than flipped truck manifolds.
Old Aug 15, 2006 | 05:42 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
If you flip the stock manifolds on the truck, would it interfere with any accessories.
Old Aug 15, 2006 | 06:12 PM
parish8's Avatar
single digit dreamer
i tried fliping the stock manifolds every wich way and it wouldn't work well. building my own turned out to be easier.
Old Aug 15, 2006 | 06:27 PM
kbracing96's Avatar
Flipping them up, puts them to close to the coils in my opinion. Swapping them like the F-body guys front mounts, you would have to ditch the AC on the pass side and they hit the power steering pump on the drivers side. I'm with Parish, they just don't fit right no mater what you do.
Old Aug 15, 2006 | 06:33 PM
Yellowsierra's Avatar
How's it going matt??? aka Cammin03 He owes me $400 for the turbo kit I done for him....
https://www.performancetrucks.net/fo...d.php?t=350633
