going thru relays w/ the inline Bosch...
Old Aug 10, 2009 | 10:46 AM
Superado's Avatar
11 Second Truck Club
Default going thru relays w/ the inline Bosch...
first one was a small one that said 30amp on it that came w/ the MSD FPB I bought...
( which I really don't need now w/ the in-tank Walbro feeding the in-line Bosch )
thinking it was the MSD wigging out, I bypassed it and realized it was the relay...
changed it out and all was good until that relay started nuttin' up as well...
have been told to get a Bosch 30amp relay and socket/pigtail:
http://cgi.ebay.com/ebaymotors/Bosch...Q5fAccessories
saw online where one guy went to this:
http://cgi.ebay.com/ebaymotors/QUALI...=p4506.c0.m245
I do like the screw connections for power in and out...but...
I can get a starter solenoid cheaper than that and it should have no problem with amperage either...
any suggestions or comments?
Old Aug 10, 2009 | 06:18 PM
Superado's Avatar
no comments?
Old Aug 10, 2009 | 06:35 PM
Mangled03gmc's Avatar
Baltimore Whore
So the bosch relay is being a dick, not the one for the intank??
Old Aug 10, 2009 | 06:43 PM
Superado's Avatar
correct...stock relay works fine for the Walbro in-tank...
this is the second one that's nutted up on the Bosch...two different brands of 30amp...neither Bosch however...which I have read are made by Tyco now...
Old Aug 10, 2009 | 07:25 PM
Baltimore Whore
So have you tried a tyco(bosch) relay.. If you havn't I would give it a shot... IIRC i don't think that pump draws anymore then 16 amps
Old Aug 10, 2009 | 07:39 PM
Truckshop's Avatar
if you are gonna use a solenoid make sure it is a constant duty one. a regular starter solenoid will cook itself.
Old Aug 10, 2009 | 08:21 PM
Superado's Avatar
haven't...may just order one...less than $10 w/ socket/pigtail...shipped
really? hmmmmm...the one that I read about someone actually using was one for a snow blower of all things...
Old Aug 10, 2009 | 08:22 PM
lowoh8's Avatar
just buy a solenoid
Old Aug 11, 2009 | 10:13 AM
Superado's Avatar
looks like I will be going with a continuous duty solenoid...
spoke w/ a local performance shop and they said that the DD'ing of the vehicle is prolly whats killing the relays...said they use NAPA ST95's all over their street cars for pumps, fans, etc...anything that pulls a good bit of amperage for extended periods of time...
gonna p/u a BWD equivalent (S672) tonight @ O'Reilly...
$A_Money$81
Mar 27, 2023 10:25 AM
Wrecker 426
Sep 30, 2015 09:39 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
slowlsx
Jul 13, 2015 04:18 AM
