going with STS later, what size
Old Nov 17, 2007 | 01:12 AM
seadoo's Avatar
Default going with STS later, what size
im going with a STS kit after I finish the custom interior and trailer on my boat. I only want the kit for the street and for towing. mainly getting the STS because of all the increase MPG while street driving and the 2-3 MPG increase while towing. my truck is and will be a stock 5.3 !cats and a muffler after the turbo. I will have a FMIC and alkycontrol kit. What size turbo will match my needs for the best towing experience with hill climbs and better MPG?? also, trans will be built with a stock TC tuned.
Old Nov 17, 2007 | 07:27 AM
Spoolin's Avatar
GFYS and STFU
GT-67 ftw
Old Nov 17, 2007 | 09:12 AM
03sierraslt's Avatar
I would have said the 60-1 (standard turbo) but Spoolin has one so he would know better then me.
Old Nov 17, 2007 | 09:16 AM
BlownChevy's Avatar
blownerator
25 Year Member
The GT67 with the right exhaust side is going to get you more bottom end than the base turbo supplied with the kit. The smaller AR will allow for quicker spools on your 5.3, but look out.....there is enough there to shatter a piston pretty quick. If you are interested I am going to be taking my intercooled STS system off and selling it in the next couple of weeks.
Old Nov 17, 2007 | 09:35 AM
Wilde Racing's Avatar
How do I change this text
I had a 60-1 with a GT wheel that spooled very quick on my old 5.3, now I have a GT-67 on a 5.3. It spools alittle slower, but it can move a whole bunch more air.
Here is my though on this....
If you know that the 5.3 will be you power plant choice forever, then get the 60-1, if you are thinking of doing a 6.0 swap (helps with towing BTW) get the GT-67..
Old Nov 17, 2007 | 09:39 AM
seadoo's Avatar
thanks blownchevy... but in a couple weeks i will have spent a few grand on the boat and trailer.
what size AR do you recommend that I get with the GT67 STS kit? also, at 5-7 pounds, and a tune, will I have to worry about a busted piston? as long as I watch EGT's and such??
Old Nov 17, 2007 | 09:45 AM
BlownChevy's Avatar
blownerator
25 Year Member
good point
seadoo's Avatar
how bad would the towing be between the 60-1 and the 67 on a 5.3 ?? I want the 2-3MPG increase towing that everyone claims to get? sometimes having to climb steep grades and such?
also, mind you that the TC will be stock
BlownChevy's Avatar
blownerator
25 Year Member
see wilde's post.
I have a 81 A/R on my GT67 and it is spooled up by 3K.
Old Nov 17, 2007 | 09:49 AM
seadoo's Avatar
thank you. what is the stock AR that comes on the STS GT-67 kit? I also read his post, I take everything he says to the true real world experience because he tows alot. and I trust his, yours, and some others words to be gold.
