Going for big boost on a forged 5.3
Old Sep 2, 2009 | 09:32 PM
old motorhead's Avatar
Originally Posted by silver-mod-o
They come stock on 5.3's so I'd say yes... The 317s aren't terrible, but they'd need to be massaged to fit properly as their made for a 4" bore ideally.
I run them on the 3.906 bore of my 347 but they've been worked over by WCCH specifically for this setup.
The 243's I have came from an LS2. They also came stock on LS6's. Never heard of them being available on 5.3L's, but I've led a very sheltered life.
Old Sep 2, 2009 | 11:59 PM
Rick_Vor's Avatar
Using your 3.779 bore and a OEM MLS .051 gasket and assuming the deck height to be about -.008 and 2.0 cc's for the piston head volume gives a compression of 10.397. A set of 243's will drop you down to 9.98 and 317's lower you to 9.25. I think the 243's will require a lot of Meth and reduced timing to run 15lbs. If your not going to run Meth, I think you would be better off running the 317's. With a 220 cam, I wouldn;t be surprised if a good tuner could make ,ore power with the 317's. That said, the 243's will be more responsive off boost.
This is a link to the Compression calculator I used if you wnat to play with it -
http://www.kb-silvolite.com/calc.php?action=comp
Rick
Old Sep 3, 2009 | 12:01 AM
Rick_Vor's Avatar
I think GM changed the casting number to 799 on the "243" castings they use on the LS2's and the new 5.3's.
Rick
Old Sep 3, 2009 | 11:42 AM
zippy's Avatar
At only 15psi if you run good fuel or meth you can get away with your current compression. A set of 243's or 799's would flow better though.
Old Sep 3, 2009 | 12:12 PM
ssavalanche's Avatar
I stuffed together a forged 5.3 with flattop pistons, 241 heads, GM MLS gaskets, arp studs and a LPE gt2-3 cam. @16 lbs boost this thing really sings. It gets regularly beaten like a drum and asks for more. Pump gas and no meth.
Old Sep 3, 2009 | 04:38 PM
06chevy5.3's Avatar
Look up Cometic and see what they can do for the thicker gaskets.
ARP head studs would be a must as well for reliabilitys sake.
As far as the heads are concerned, 317s will cause valve shrouding on that small of a bore. I'd personally do some 243s... Shoot for a compression ratio for a hair under 10:1
Could Wiseco put bigger valve reliefs or a dish in them maybe to drop some compression??
I got on commetics site all they make is ls1 gaskets with bigger bores dont know if thats gona seal properly.... yah im sure wiseco could but it would cost some more money
Originally Posted by Casey2323
u plan to run a decent size cam?? 220? nothing was said/ask about camshaft....
The cam is not huge at all its a meduim size cam it is already installed before the engine blew
Rick
I can get a set of 317s for cheap or next to nothing cheapest ive seen for 243s is 500 bucks... just talked to my tuner today they recomended 317s as well.... Ide like to keep it streetable and dont wana run race gas all the time or meth....
241 heads??? what are those
Old Sep 3, 2009 | 05:49 PM
06chevy5.3's Avatar
Nvm i found it 241s= LS1 heads 66.7cc chamber gives me 9.79:1.....
Found a pair on ebay for 100bucks, sounds like my awnser thanks.....
Old Sep 3, 2009 | 06:29 PM
silver-mod-o's Avatar
Hunt&Fisherator
I also have 6L 4" 5 layer MLS gaskets on my 347... A little bigger gasket than the bore shouldn't hurt anything.
Old Sep 4, 2009 | 06:53 AM
LsxCody's Avatar
241s would work well but I'd still go with either 317s or 243s
Old Sep 4, 2009 | 08:39 AM
Rick_Vor's Avatar
2nd that. The 243's are so expensive because they flow so much better than the LS1 and LM7 heads. The 317's have the same ports and flow as the 243's but the big chamber turns most people off unless they are going boosted (as in your application). They are so cheap because there are a million sets around.
Cylinder Valve Lift in Inches
Head .200 .300 .350 .400 .450 .500 .550 .600
LS1 137 187 207 223 228 237 242 243
LS6 156 204 225 243 257 267 275 278
Go with the 317's.
Rick
