go 90mm TB or go home?
Old Jul 14, 2006 | 11:09 AM
  #211
wkdivr's Avatar
Originally Posted by moregrip
BC says his opens 100%, when I did the test on mine it did not open 100%.
Off Topic: It's been crazy over here(NAVY) with support over in your general region lately
Hmmmmmmmm......got about 60 more days to study, and ponder the subject! Hope any other 5.3 people that did the conversion might chime in.
Old Jul 14, 2006 | 11:11 AM
  #212
moregrip's Avatar
what a rush!
do us a favor and figure it out
Old Jul 14, 2006 | 12:24 PM
  #213
LBSBLOWN's Avatar
I did the 90mm conversion on my 2005 5.3 Sierra 4x4 and I have the same problem, the scanner tps says 100% but the actual TB blade will only open
somewhere between 75% & 85%.
Old Jul 16, 2006 | 11:20 AM
  #214
Superado's Avatar
11 Second Truck Club
just a bit of humor...TB blade wasn't opening all the way on cablebandit's new 90mm TB on his freshly installed turbo'd set-up yesterday...
we found the problem...
a hose clamp directly behind the cable controlled TB lever...
turned the gear around...problem solved...
Old Jul 26, 2006 | 08:54 AM
  #215
LBSBLOWN's Avatar
Bump,
Any word on a fix yet for the 90mm TB not opening 100%.
Old Jul 26, 2006 | 09:00 AM
  #216
Holty's Avatar
Notorious BIG
yeah, that would be sweet if someone could figure this out.
Old Sep 1, 2006 | 09:03 PM
  #217
LBSBLOWN's Avatar
Bump,
Any word on a fix yet?
Old Sep 2, 2006 | 02:28 PM
  #218
moregrip's Avatar
what a rush!
Maybe CrashDummy will have some insight, anyone PM our tuning guru?
Old Sep 10, 2006 | 05:53 PM
  #219
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Lil update:
I got mine plugged in today and played around with it a bit. Bad news: the pcm sets a limit at 100% on the parameter controlling the TB blade (possibly to protect the circuit that feeds the blade motor) or I'd have a fix to announce. Good news: I did get it to open a tiny bit more (maybe 3-4%) by adjusting *when* the PCM commands 100%. I watched my log and noticed most of the time my pedal claims to be at 99%... I changed the 99% fields from 96% open to 100% and got a littler bigger movement from the blade.
This may require a custom OS to fix. I'm going to poke around my OS and see what I can see / ask Ross for help
I'm beginning to wonder if the circuit is under powered with this tac or if its jsut software like I first believed.
Old Sep 10, 2006 | 08:06 PM
  #220
Holty's Avatar
Notorious BIG
thanks Erik, keep us posted.
