go 90mm TB or go home?
Notorious BIG
I'm really fighting with myself on this decision and wanted to get input from you guys here. I can't decide if i want to do the 90mm TB conversion that WCCH offers or not? My truck is a daily driver and need it to be reliable (within reason). If i go with the 90mm TB am i going to have to do alot of tuning to get it to run right? Also, can i get away with the 42lb injectors i'm running now, or do i have to go with the 60lb injectors? i know those will be a tuning nightmare, even with help from zippy. what would you guys do if you were in my shoes? am i going to see big gains by just going to a 90mm TB?
blownerator
You will see about 25-30 rwhp just by bolting it on, I highly suggest doing it. You will see some more power once you tune for the TB (not needed but reccomended). I have it done on mine and have not had one ounce of trouble, just buy the entire kit from Richard and get er done.
High on diesel fumes
For comparison sake...I am running a Radix'ed LQ9, 3" pulley at about 7 psi, Nick Williams 90mm TB, and I hit 100% duty cycle on my 43lb'ers right around 5900 RPM. It's a little rich right there at the top, so once I get it leaned out I can probably stretch the RPM's out just a little more, but I think somewhere around 6000 RPM is gonna be the limit.
Notorious BIG
Notorious BIG
blownerator
thats what i figured, but wasn't sure on tuning for it and what all was involved. i know tuning for the injectors would be a HUGE hassle. In your opinion, does the 90mm TB mod normally require the injector upgrade?
11 Second Truck Club
Originally Posted by peppersac
Where can you buy that kit at?
