go 90mm TB or go home?
Old Jun 28, 2006 | 11:32 PM
  #201
DrX's Avatar
DrX
Actually, the LS2 TB shouldn't work at all with the newer truck PCMs/OSs if the PCM could see the TPS signals. This is because the newer TB's dual TPS signals move in the same direction while the LS2 and 01-02 dual TPS signals move in opposite directions. I'm guessing that this would trigger a TPS correlation DTC. So the translation of the TP signals into %TP and the correlation checks have to be performed by the TAC module and then relayed to the PCM. So how is the same TAC module able to adapt to the wider sensor range in one application and not the other?
Old Jun 28, 2006 | 11:50 PM
  #202
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The TAC module change corrects the differences in the TP1 and TP2 directions but the PCM is where most of the "intelligence" of the ETC system is located. I think this is pretty much confirmed by the huge number of ETC tables that are contained in the PCM calibration.
Old Jul 5, 2006 | 11:44 PM
  #203
anything new on the tunning from hpt
Old Jul 13, 2006 | 06:02 PM
  #204
Bill Reid's Avatar
Bumpin' this one up... patiently waiting for the fix
Bill
Old Jul 13, 2006 | 06:06 PM
  #205
leftcoast32's Avatar
FormerVendor
Got a pm back from Chris at HP Tuner today. He says they have not found anything yet.
Old Jul 13, 2006 | 06:34 PM
  #206
Bill Reid's Avatar
... as long as they are still working on trying to figure it out thats cool...
Bill
Old Jul 14, 2006 | 10:14 AM
  #207
moregrip's Avatar
what a rush!
maybe we can re-gear the TB's if the tuning does not pan out. any watchmakers in the house?
Old Jul 14, 2006 | 10:59 AM
  #208
wkdivr's Avatar
Grippy, did you, or BC notice the same deal with the blade opening less than 90 deg.? I'm wondering if it only is affecting to 6.0 cal, and not the 5.3. I haven't put mine on, yet, still in Afg.
Old Jul 14, 2006 | 11:03 AM
  #209
moregrip's Avatar
what a rush!
BC says his opens 100%, when I did the test on mine it did not open 100%.
Off Topic: It's been crazy over here(NAVY) with support over in your general region lately
Old Jul 14, 2006 | 11:04 AM
  #210
BlownChevy's Avatar
blownerator
25 Year Member
you could not do that, it will set a TPS code.
