go 90mm TB or go home?
#103
Notorious BIG
so out of everyone that has done the 90mm TB conversion, are zippy and I the only ones that have experienced this problem? (ie the throttle blade not opening fully).
#104
#106
Notorious BIG
Originally Posted by krambo
Like I said holty,...I do see the issue you are having. Can you quantify the amount of blade movement that is required to show a full WOT? I'd say I have another 5-8* I can force it open with my finger.
I would say mine is also about 5, maybe 10 degress away from being at 90* when at WOT.
#107
With my Nick Williams TB I had to make a new cable bracket to get the TB blade to work right. After that i have perfect TPS. Then again I have an '01 setup and not the DBW.
#109
Originally Posted by thunder550
You ever figure out the cruise control issue?
#110
I first checked my stock setup with my HPT scanner connected.
stock the TB goes all the way open 90* at 100% TPS indicated just before the throttle pedal is all the way down.
Next I checked the 90mm stuff, it will only open 75% of the way,
the scanner shows that the throttle is at 100% when the throttle pedal is only at 75% if you push the throttle more nothing changes still indicates 100%
and the TB is still only 75% open, I think this is a problem and my be why some are not seeing the expected gains from this mod.
attached is a pic of my stock tb at WOT and a pic of the 90mm at WOT.
BTW this is on my 2005 GMC truck in the sig.
