Gen-TT Truck Twin Turbo Kit
Old Aug 9, 2007 | 04:35 PM
  #91
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by Spoolin
I think 500rwhp is attainable at 10psi with meth and a good tune. JMHO
However, as you mentioned in your post dyno numbers and not track numbers which tell a better story and more accurate info on the set-up.
Ya, it might be possible, I was just going off of what his post said, it said less than 10psi and no mention of meth, so that's why I thought it wasn't possible.
With meth, 10psi, a trickle of race gas, lots of timing, and keeping the intercooler cold, i think 500hp is possible, but just by slapping the turbo system on and running less than 10psi, that's a tuff one.
The truck's initial power is on the high side from what I typically see. At least we can go off the gain after the turbo.
later,
allen
Old Aug 9, 2007 | 05:33 PM
  #92
quicksilverado's Avatar
Originally Posted by FarmTruc
I'm not trying to bash this kit, actually it has nothing to do with the kit, I think it looks pretty good so far, but I don't think you're going to hit 500rwhp on a stock truck, 100% power increase is hard to get on a truck for some reason.
With other kits, we see about 120-150hp over stock on 5-7psi. Let's say a stock 5.3L puts down 230rwhp, another 100 then it's 330hp (hey i can add, lol), then 150hp, it's 380hp, which is damn good.
You're still 100+hp short with only 3-4psi more.
The LS1's, LS2's can hit this, but not the 5.3L. The most I've seen from a front mount turbo on a stock truck with about 7 psi, with a good tune that is able to be street driven is about 415hp, still quite a bit short from 500rwhp.
You may be able to get this with some dyno tricks, like keeping the intercooler cold, running race gas and lots of timing, but in street form/tune, I anticipate it won't put 500rwhp.
BUT, prove me wrong, I'd love to see a kit out there that will put 500rwhp just from a turbo or two, and fuel upgrades.
Of course, some dyno's read different, so I guess it's possible, but the real test will be the MPH at the dragstrip.
keep us posted,
allen
Never dynoed the sts kit on the stock 5.3. According to weight and trap speed the engine put down in the 490 range to the wheels. Stock 5.3 with asm lt headers, t67 @ 8psi, no I/C 93 octane and meth. Race weight 4600 lbs. Trap speed 110.87 mph.
Old Aug 9, 2007 | 08:36 PM
  #93
kbracing96's Avatar
I don't know why people have a problem with the idea of an electric pump returning oil to the motor. STS has have very little problem's with theirs. I think I've heard of maybe 3 failures, and the last time I talked to them (which was a LONG time ago) they said they had over a 1000 kits out there. If there was a oil pump failure problem, I'm SURE that's ALL you would here about them on these boards. I know mine has at least 40k on it and the only problem I had is when it got below 0* the oil was to thick when I first started the truck for it to pump in low speed and it would blow the fuse. So I just put a switch on it to run on high speed all the time when it was cold and problem solved. Think about it ALL of you truck depend on an ELECTRIC fuel pump to supply 58 psi of fuel to the motor. How often do they fail?
Old Aug 9, 2007 | 08:50 PM
  #94
moregrip's Avatar
what a rush!
the kit is looking very nice! Looking forward to the results
Old Aug 10, 2007 | 09:34 PM
  #95
RotaryResurrection's Avatar
Enough that I have changed 2 out on the side of the road, and now have a cutout access panel under my back seat and carry a spare pump with me in the truck.
Old Aug 16, 2007 | 07:11 AM
  #96
Street Tuna's Avatar
FormerVendor
Just saw this post. Dont worry Rotary the pumps we use are a vane style pump rated to thousands of hours continuous operation, and should the need ever arise they are fully rebuildable. Expect zero failures with these
Old Aug 16, 2007 | 07:12 AM
  #97
FormerVendor
Work on the GM Truck Gen-TT Intercooled Twin Turbo system is progressing well at the moment, just patterning the production pipes at the moment, and final installation for tuning will begin tomorrow
Thats when all the fun stuff happens
Old Aug 16, 2007 | 01:42 PM
  #98
Q8 6.0's Avatar
will you offer tuning with it?? dose it come with good instructions??? with step by step tips how to remove grin and act normal before walking inside the house.
thanks
Old Aug 16, 2007 | 04:11 PM
  #99
FormerVendor
We will be offering a base tune file in HP Tuners
Our instruction manuals have always been comprehensive so thats not a problem, and the grin, sorry, you cant avoid it
Old Aug 16, 2007 | 05:14 PM
  #100
408 Sleeper's Avatar
I like the location of the turbos to keep the extra heat out of the engine. On a 4wd what happens when you do stream crossings or hit some deep water?
