Gauges installed. Are they reading correct?
Old Apr 28, 2007 | 10:24 AM
OneBadSSS's Avatar
Default Gauges installed. Are they reading correct?
I just finished installing Autometer electric Boost/Vac and Fuel Pressure gauges and I took the SS out for a test drive to see what kind of readings I'm getting. I don't have any prior experience with an F/I setup so I want to be sure that my readings are "normal." Here's what I'm seeing:
At Idle:
16 Vac on the boost gauge, 61 PSI on the fuel pressure gauge
At 65mph cruising:
10 Vac, 60 PSI fuel pressure
At part throttle (accelerating from 65mph to 75mph)
0 Boost/Vac, 60 PSI fuel pressure
At WOT (60mph to 80mph blast)
6 lbs. of Boost, 55-56 PSI fuel pressure
Decceleration (65mph down to 35mph @ the off ramp)
19 Vac, 60 PSI fuel pressure
Do those readings sound ok? Current mods are in my sig BTW...
Old Apr 28, 2007 | 10:32 AM
BigTex's Avatar
What year is your truck? I'd say those readings are correct for a 2004+ year truck. The fuel pressure shows the characteristics of a tank mounted fuel pressure regulator. On a 03 and older vehicle, you'd see the opposite - mid 50s psi at idle, ~58psi at part throttle and low 60s psi at WOT.
Old Apr 28, 2007 | 10:47 AM
OneBadSSS's Avatar
My truck is an '05 SS (AWD) and it has the Magnuson in-tank fuel pump kit installed...
Old Apr 28, 2007 | 10:58 AM
xsports33's Avatar
Those are very similar readings to mine, only exception is at WOT my fuel pressure only drops to about 58.
Old Apr 28, 2007 | 11:19 AM
BlownChevy's Avatar
blownerator
25 Year Member
You are JUST fine......All readings are within spec.
Old Apr 28, 2007 | 12:14 PM
OneBadSSS's Avatar
Thanks a lot guys, I appreciate the feedback!
Hey Brian, when are the crank pinning kits going to be available for purchase? I'm very interested in picking a kit up from you! Let me know, thanks!!
gaps
Oct 15, 2015 02:53 PM
murderedSS
27
Oct 12, 2015 11:13 AM
Justin87gn
Sep 10, 2015 12:06 PM
97gmc
22
Sep 8, 2015 10:56 PM
silver-mod-o
Sep 7, 2015 10:22 PM
