fueling questions... "do i need this much"
Old Feb 9, 2010 | 01:42 PM
1989k1500's Avatar
Originally Posted by denali_on_26's
i will only be what pump gas will bring me to....
like i said:
stock heads
stock intake
pump gas
i am just building a fun street truck...
HOW FAR (hp) WILL THE SOCK RAILS/REGULATOR TAKE ME SAFELY???
SilveradoL33 made 681whp through an 80e and 9.5" rear end on 35 inch tires with stock return rails. So somewhere above that is the limit. lol
Old Feb 9, 2010 | 08:56 PM
eviltwin_1987's Avatar
i will be doing the same but on a 370
317's
80lb injectors
stock rails
dual walbros
pt88 (if i could ever find one for a good price)
let us know how it works for you
Old Feb 10, 2010 | 10:30 AM
1BADAZZSS's Avatar
Originally Posted by TurboBerserker
You are fine for your goals. I ran stock rails, lines and regulator into the 800hp range before swapping rails and regulator (which I did so I could swap to a vic jr -- not because I was out of fuel). Parish8 ran stock lines, regulator and rails to 11xx rwhp and 10.04 quarter mile.
True that and on a truck mani.
denali_on_26's I think your injectors will max out before the stock rails will. Are those 80lb injectors high impediance?
Old Feb 10, 2010 | 12:01 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
..............how do u tell??? and what does that mean??? they are the SIEMENS DEKA 80's they are the skinny ones
Old Feb 10, 2010 | 12:57 PM
1BADAZZSS's Avatar
If they do not run off a injector driver or some sort of resistor pack then they would be a high impedance Injector.
Old Feb 10, 2010 | 01:16 PM
i bought them used from another member and he did not say anything about them needing anything else...
whats the difference
Old Feb 10, 2010 | 07:22 PM
they are igh impedance. no need for a box. what feed line are you running from pumps to rail?
Old Feb 10, 2010 | 08:03 PM
-8an .
Old Feb 11, 2010 | 05:11 PM
How are you connecting the -8 to the truck rails? I can't find a adapter to -8, only -6 for the rails.
Old Feb 11, 2010 | 07:44 PM
reducer then....lol
i haven't gotten that far yet
