fueling questions... "do i need this much"
SilveradoL33 made 681whp through an 80e and 9.5" rear end on 35 inch tires with stock return rails. So somewhere above that is the limit. lol
You are fine for your goals. I ran stock rails, lines and regulator into the 800hp range before swapping rails and regulator (which I did so I could swap to a vic jr -- not because I was out of fuel). Parish8 ran stock lines, regulator and rails to 11xx rwhp and 10.04 quarter mile.
denali_on_26's I think your injectors will max out before the stock rails will. Are those 80lb injectors high impediance?
