Fuel questions for turbo 5.3
Old Nov 12, 2010 | 11:20 PM
kazfan30's Avatar
Default Fuel questions for turbo 5.3
Guys, what are you guys getting away with as far as fuel system on your 5.3s? I have the mild 5.3 in my sig.. cam and bolt-ons.. I was looking into KBs kit with a 70mm at around 7 psi. Can i get away with a walbro 255 in the tank and some delphi 44# injectors since i already have them.. and what kind of power can those fuel injectors and pump support?? Would love with the turbo and a few more items to get in the mid 400's rwhp range. Thanks in advance
Old Nov 12, 2010 | 11:24 PM
black04's Avatar
You are good on fuel and should be in the mid 400 range. I run a 255 intank and 60# injectors on a 5.3 with 10psi. This is on a returnless system.
Old Nov 12, 2010 | 11:29 PM
gavin2005's Avatar
everone says walbro 255 and 42lb injectors will support 500rwhp.you should be fine on 7lbs of boost.theres guys running that same fuel setup on 12lbs of boost.i have 42lbers and walbro 255 and im running 5lbs of boost.i would run more boost if i didn't still have stock tranny
Old Nov 12, 2010 | 11:35 PM
kazfan30's Avatar
Thanks guys... I appreciate the responses
Old Nov 13, 2010 | 12:14 AM
bighoss77's Avatar
whew... that asnwered my question too! i have 42lb injectors and a pro-charger frame-mount booster pump for my vortech v-2 setup! sounds like i should be good with fuel. sorry to thread jack, but will this be okay with a return system and stock fpr?
Old Nov 13, 2010 | 08:56 AM
blue0453's Avatar
Im running a 255 with 42lbrs and dynoed 410, my injectors were 110% at 8psi. Get the 60lbrs.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
76k10chase
Jul 17, 2015 01:48 PM
