Fuel pressure drop?
Old Feb 13, 2007 | 06:11 PM
Ruffrider5.3's Avatar
Default Fuel pressure drop?
Looking at my gauge at wot, the fuel pressure drops off quick to like 45 or so. What do I need to do now? I have an intank 255, but I did not mod the bucket or anything. Is this a voltage problem or what? Pump maybe going bad? I havent really put it through any rough duty.
Old Feb 13, 2007 | 06:42 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Did this start after the new pump install?
Fuel pressure regulator change?
Add a Magnavolt or boost-a-pump?
Does it happen at the same rpm and boost level all the time? If so, maybe the pump just can't keep up. Any recent changes to the setup? More boost?
Old Feb 13, 2007 | 07:36 PM
The pump has been in for 2 years, but I just started putting boost to it. Yeah it happens usually at the same time under boost.
Old Feb 13, 2007 | 08:03 PM
1SlowHoe's Avatar
I bet the pump is fine. You're asking an awful lot of a single pump to push fuel to a boosted engine. That's why you see guys with dual in-tank pumps or inline pumps and a voltage booster, or all of the above. I run the stock intank, 255lph walboro inline and a KB BAP. With 42# Ford green tops I see 80% IDC at 6000rpm. 6L with 9psi.
Cheapest way out is a boost a pump or magnavolt. For another $125 or so you can add the inline pump and put the boost a pump on that so you don't over work the intank which is a PITA to change compared to the inline which you could swap in 15 minutes. (and that my friends is a run on sentence)
If you decide to go that way PM BlownChevy. He can get you both at a good price.
Old Feb 13, 2007 | 08:18 PM
you can do a hot wire kit too.
Old Feb 13, 2007 | 09:10 PM
HUH? I prolly should get a boost a pump or something......bahhhhh another 300 bucks down the tubes.
Old Feb 13, 2007 | 09:36 PM
http://www.ls1speed.com/catagory.cfm.../%20Electrical
Anyone know if those v plus volt boosters will work on our trucks? I had on on my camaro and that thing worked great and looky at the price.
Old Feb 14, 2007 | 09:08 AM
blown3qtr's Avatar
Have you checked voltage at the pump? Or the electrical connector at the pump? (That is a sentence fragment. ) I know the connectors at the module can create some resistance, and even melt. Check for any deformation/discoloration. The pump's flow is relative to voltage and pressure.
I'm running an intank 255 w/ 60#ers and 8psi. It seems to be working fine. I'm not saying you don't need more pump, but I would check the electrical system first. Hotwire kit does sound like a good idea though IMHO.
Old Feb 14, 2007 | 11:17 AM
Where can I get a hotwire kit for the truck?
Old Feb 14, 2007 | 11:28 AM
thunder550's Avatar
High on diesel fumes
Get a Walbro inline - $125 as stated above. I ran a stock intank and a Walbro inline to 9 psi on my 6.0L with no pressure drop.
