fuel injectors
hey these good injectors to run a whipple charged 2009 denali
80 lb Short D5 High-Z Fuel Injector MT
Item Code: FI114700
Weight: 40.50GM
Manufacturers: Siemens (Continental)
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: A2C32624700
Coil Resistance Ohms: 12
Spray Pattern: Cone
Series: DEKA 5
Connector Type: Minitimer (Bosch EV1 - Jetronic)
O-ring Type: Viton
E85 Compatible: Yes
Weight (non-shipping): 29GM
Test Pressure PSI/KPa: 43.5/300
Test Solvent: Heptane
Item Code: FI114700
Weight: 40.50GM
Spray Pattern: Cone
Series: DEKA 5
O-ring Type: Viton
E85 Compatible: Yes
Where are you ordering them from and for how much? The biggest problem with a lot of injectors is tuning them... you need to get accurate data on their flow rates to tune correctly.
GXPJAY
Feb 13, 2022 08:15 AM
