fuel injectors
Old Jul 13, 2013 | 04:09 PM
ou812sm's Avatar
Default fuel injectors
hey these good injectors to run a whipple charged 2009 denali
80 lb Short D5 High-Z Fuel Injector MT
Item Code: FI114700
Weight: 40.50GM
Manufacturers: Siemens (Continental)
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: A2C32624700
Coil Resistance Ohms: 12
Spray Pattern: Cone
Series: DEKA 5
Connector Type: Minitimer (Bosch EV1 - Jetronic)
O-ring Type: Viton
E85 Compatible: Yes
Weight (non-shipping): 29GM
Test Pressure PSI/KPa: 43.5/300
Test Solvent: Heptane
Old Jul 19, 2013 | 02:25 PM
Vortec350ss's Avatar
Where are you ordering them from and for how much? The biggest problem with a lot of injectors is tuning them... you need to get accurate data on their flow rates to tune correctly.
Old Jul 19, 2013 | 04:48 PM
03sierraslt's Avatar
That is the key, getting the right injector data. Talk to your tuner prior to getting them to make sure he has access to the correct data.
GXPJAY
Feb 13, 2022 08:15 AM
adunphy
Feb 22, 2016 06:38 PM
RONIN LSX
Aug 11, 2015 12:03 AM
jrplz
Jul 9, 2015 12:07 AM
