Fuel help
Old Apr 25, 2017 | 06:39 PM
m6c5's Avatar
Default Fuel help
What is the most power that you can get before your stock fuel lines become restrictive and need to be upgraded?
Im trying to figure out if I need to go to a half in line or not.
Old Apr 25, 2017 | 07:47 PM
FFDP's Avatar
If I remember right, sloppy mechanics went all the way to 800-900hp range on stock lines/stock truck rail before it getting to the point of fuel flow being a concern.
Old Apr 29, 2017 | 12:03 PM
m6c5's Avatar
Thats good to know, I figured there would be more people who had pushed the limits of the fuel system than that.
Old Apr 29, 2017 | 07:47 PM
kbracing96's Avatar
On gas with meth and a return fuel system, a few have hit the 1K mark. I've gotten to 800 with a single 450 pump on stock lines.
Old Apr 29, 2017 | 09:20 PM
m6c5's Avatar
Were you running meth on your setup? And did you start to see any hits of pressure drop at all?
Old Apr 29, 2017 | 10:34 PM
kbracing96's Avatar
Yes, I have meth. I don't have a pressure gauge, but the wideband never went lean.
Old Apr 30, 2017 | 07:47 PM
m6c5's Avatar
Ok well it looks like I will try and stick with the stock lines then. I would like to hit 800 but Im not planning on using meth at the moment.
Old May 1, 2017 | 11:45 AM
Atomic's Avatar
I have a gauge for that
My math said at around 1000rwhp mark there is about a 10psi drop in pressure due to line size. Not a big deal depending where your pumps are in their curve.
