fuel filters with big power
Old Aug 16, 2010 | 09:59 AM
sureshot's Avatar
Default fuel filters with big power
I'm sticking this in the forced induction section because most guys running big power have some kind of forced induction. My question is this: At what point does the stock fuel filter become a restriction in the fuel system? When should an aftermarket fuel filter be considered and how many microns should the filter be?
Old Aug 16, 2010 | 10:39 AM
charcold-bowtie's Avatar
i run 100micron pre pump, and 10 micron post pump. I have a 4301 mounted inline
Old Aug 16, 2010 | 01:15 PM
sureshot's Avatar
So you're running a stock intank pump, and a magnafuel inline? Did you run bigger lines as well? I have a Bosch 044 intank, and was thinking it might benefit the pump not to be pushing through a stock filter. Just trying to see what others were doing.
Old Aug 16, 2010 | 01:27 PM
Mangled03gmc's Avatar
Baltimore Whore
I think teh stock filter is fine, along with fuel lines, well into the 900 hp range.. Only facts i have, is that parish was making 1000hp to the wheels, was all on stock fuel stuff( other then pumps)
Old Aug 16, 2010 | 01:42 PM
no intank, just a bulkhead then a straw into the tank. -10 feed and -6 return, all stainless with AN fittings.
Old Aug 16, 2010 | 02:19 PM
sureshot's Avatar
How is the straw held into place? Sorry for all the questions!
I've heard that too. Ever since Russ and I pullied down, we are running a little leaner than we want to be for the last 400ish rpm's. We were just finding it hard to believe that we maxed the pump out. Just trying to get ideas.
Old Aug 16, 2010 | 07:57 PM
jetttstream's Avatar
How high in regards to the 'bottom' of the tank is your bulkhead?
Just curious how much suction the 4301 actually has.
My buddy with a 4301 has a bulkhead on the bottom rear of his tank that then feeds his pump.
Old Aug 17, 2010 | 04:39 PM
tarinitup's Avatar
9 Second Truck Club
Something to consider is the amount of meth used to compensate for the fuel system.
Old Aug 17, 2010 | 04:45 PM
bulkhead, then a hose barb with a 1-2inch piece of heater hose stubbe into tank.
My bulkhead is thru the stock sender assemble and the 4301 is mounted on the driverside frame rail right in from of the stock tank
Old Aug 17, 2010 | 04:49 PM
return is thru the assembly to. Looks like i didnt take a picture. whoops
