Fuel + Boost question!
Old Jul 23, 2009 | 08:21 AM
lownslo's Avatar
Default Fuel + Boost question!
I have my kbracing kit with a 70mm bolted to a 6.0 on my truck! I went to fast 60# injectors. It was originally a flex fuel truck, and in all my searches I find that flex fuel has bigger injectors and pump from the factory.
My question is: Can I use my stock pump to go from a comfortable .3bar, 4psi spring in my wastegate to a .5bar, 7.25psi spring without changing the fuel pump? I would love to keep that stock if possible because a get a huge discount on gm parts if anything ever happens and i hate to pull the good working pump if it will possibly work!
thanks in advance!
Old Jul 23, 2009 | 09:22 AM
silver-mod-o's Avatar
Hunt&Fisherator
how bout ya just drive it like it is so the trans doesnt end up somewhere on the hwy and buy a fuel pump.... THEN get the spring you want, or just a controller
Old Jul 23, 2009 | 09:30 AM
TX Tahoe Z71's Avatar
According to a knowledgeable source I spoke with, the stock flex pumps are about 250gph and the stock 38lb injectors are rated at 38lbs at 2 bar, while the 42lb injectors are rated at 42lbs at 3 bar (50% more pressure behind them), so what this guy was telling me is that the 38 flex fuels actually outflow the 42s. PM sent about source since it's a non-sponsor.
Please correct me if this information is wrong, I don't want to lead anyone astray and have them run out of fuel
greedygenius
Sep 3, 2015 06:51 AM
RS/SS 4.8
Aug 2, 2015 11:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
76k10chase
Jul 17, 2015 01:48 PM
