Front mount turbo, 8.1L
Old Sep 14, 2009 | 05:32 PM
Coban's Avatar
Originally Posted by kbracing96
He's talking about an 8.1L big block (496), not a small block setup. who knows how the 8.1's manifold is gonna fit once flipped, there might not be any room. Just something he's gonna have to try and see.
If I had and 8.1 truck, I try it and see!
I know what he was talking about, but i would imagine its going to be done the same way. He had a question about welding to the cast iron manifolds. I was just letting him know how the other kits were run... (i.e. there is no welding to the cast iron) and about how the connection is made, not if/how it will actually fit.
Old Sep 17, 2009 | 11:23 PM
Ender06's Avatar
So I'm gonna have to re-do the entire hot side on the rear-mount, move the wastegates, move some cold side pipeing...What less would I be doing on the front mount?
Old Sep 18, 2009 | 04:09 AM
arv8100's Avatar
Originally Posted by Ender06
So the rear mount seems to be more trouble than I like dealing with. Just little stuff that keeps bothering me. So I have been contemplating a front mount system. I was thinking of flipping the passenger side manifold and building the same style like many of the front mounts on the LS motors on this site. The stock manifolds are cast...will they work for this? Can I weld on them? Any other Pro's or Con's or forseen problems?? Any advice would be great also.
Let me save you a whole lot of trouble...flipping the manfoild will definetly not work. Tried it:if you look closely at mounting holes you can see they are at a diagonal compared to the 5.3 which are not. What ends up happening is you can bolt them up but the port is about 1inch off a no go!! Been there... you are going to have to have someone custom make you a pss side manfoild...
Old Sep 23, 2009 | 12:20 PM
Kerr's Avatar
what are your problems with the STS we might be able to help.
ARV8100 i demand videos and pictuers!!!!!!!!!!!!
Old Sep 24, 2009 | 07:59 AM
redsled579's Avatar
I <3 compressor surge
Talking
Originally Posted by kerr
arv8100 i demand videos and pictuers!!!!!!!!!!!!
x2
Old Sep 24, 2009 | 10:18 PM
TieRod's Avatar
I do believe this tread has pics of his setup. https://www.performancetrucks.net/fo...+turbo+8.1+496
X3 on vids!!!
Old Sep 24, 2009 | 10:22 PM
Ender06's Avatar
X3 on vids!!!
I new I remembered seeing that somewhere
Old Sep 26, 2009 | 11:55 PM
James B.'s Avatar
As was said, the header bolt patterns on big block heads isn't symetrical. Flipping the manifolds isn't possible, I tried this for some mock-ups of my own.
You can buy flanges from Summit and some 2" schedule 40 steel elbows and build some manifolds yourself. Custom manifolds is probably your only option.
Old Sep 26, 2009 | 11:58 PM
Ender06's Avatar
Yeah, I realize this now. I may make some custom manifolds in the future, guess i'll just stick with the but mount for now.
Old Sep 28, 2009 | 10:47 PM
arv8100's Avatar
Originally Posted by redsled579
x2
Hey guys I do have some upgraded pics since moving the Twins from rear to just under the factory exhaust manifolds. Also had changed out the A/R size on hot side from .96 to .68's (it took months to finally figure out Turbonetics had sent me the wrong size). Long story short pulled of 100+ft of Heat wrap, Stainless works long tube headers, then custom built pipes from factory headers to tubines and of course reconfig oil and charge pipes. **Night and day difference...
