Forced Guys What Are Your Iat's
Old Aug 29, 2005 | 03:48 PM
CRAZYCUTER's Avatar
Originally Posted by Chevmann99
Not sure what my IAT's are or if this helped, but I relocated my filter to the stock location, but for noise purposes, the constant bypassing on the highway and the intake noise was too much for me. I would think that the intercooler would take care of the heat, I had no trouble with mine prior to relocating the intake and I have the crappy stock 2 core.
WHERE DID YOU GET THAT KIT/DID YOU MAKE IT?
Old Aug 29, 2005 | 04:49 PM
Chevmann99's Avatar
Yes.... completely home made with the exception of the airbox (a modified K&N FIPK surround) It's made with 4" aluminum exhaust tubing, & rubber elbos. After rough fitting everything I had the aluminum piping chrome plated. It's been in there for about a year and I have had no problems with it. I dont remember the supplier for the rubber elbos or the aluminum piping but I know Turbo Hoses carries the 4" to 3.75" reducer to connect the pipe to the blower. I just got the ol' tape measure out and started measuring and then bought about 8' of 4" pipe, a few 90 deg elbos, a couple 45 degree elbos, the reducer, some hose clamps and a filter. Then started cutting and fitting it altogether, had to modify the reducer and a couple of the elbos near the blower to get everything to fit properly in the limited space and hook up the bypass hose and oil vent hose like the stock kit. All in all it was pretty easy, about $150 in parts and another $100 or so to chrome it. A little pricey and I don't know if it did anything for IAT's but, my concern was the bypass and intake noise and it took care of that really well....
Here is a couple more pics (rough stage)
Old Aug 29, 2005 | 04:58 PM
bud8fan's Avatar
Originally Posted by CRAZYCUTER
How Are You Getting Such Low Iat"s
just run one of billys 3" in and out obx intercoolers.......he even has a 4" in/out for more air
Old Aug 29, 2005 | 06:07 PM
camcojb's Avatar
I'm thinking some of these guys are posting IAT's from before the blower, not after. I've never seen one stay around 100 degrees on the boost side if the ambient temps are 100 also. If it's 100 degrees outside and the truck is fully warmed and heat soaked I'll see 150-160 degrees on the IAT's after the blower by the end of the run.
Jody
Old Aug 29, 2005 | 07:38 PM
04Denali's Avatar
my AIT on 100+* day was 126* after the SC.
I have s RADIX, stock pulley
Mark
Old Aug 29, 2005 | 08:01 PM
Where can I get this intercooler? My IAT's can get as high as 199.
Please advise.
Old Aug 29, 2005 | 08:06 PM
moregrip's Avatar
what a rush!
At the track in mid 90* temps the highest IAT's I saw was high 140* at the end of a 1/4 run.
Old Aug 29, 2005 | 08:09 PM
F8L Z71's Avatar
With the STS on my 5.3L, 14psi, and big FMIC on 72deg temps I would see a max of 107deg IATs after a full WOT frun from 15mph-95mph.
Old Aug 29, 2005 | 08:30 PM
white lightning SS's Avatar
before the meth I had 145-160 wot on 94 degree 80% humidity after meth never higher than 110
Old Aug 30, 2005 | 07:09 AM
hellbents10's Avatar
LS1Tech Sponsor
The temps I posted are right at the throttle body were the mass air sensor is. The 98' procherged c1500 has a 6.0l maf with the iat in it.
