First turbo build...
Old Feb 15, 2016 | 09:42 PM
LT4Hawk9's Avatar
Default First turbo build...
I've swapped several LS truck engines into engine bays where they didn't grow, but always N/A. That is about to change. I have a 2005 LQ4/NV4500 combo that I am putting into an older 4x4 SUV. I like the idea of a manual, but it remains to be seen if I like the NV4500 in this one with a turbo or not. I have a GT4082R turbo in hand, and would like to be in the 500-550hp range all said and done.
What I need to know is this...what else do I need to make everything all play nicely together? What injectors, fuel pump and line size, etc. What hard parts am I going to need to upgrade on the engine...intake, TB, etc?
Basically, I have an engine, a turbo, and a desire to build...now what?
Thanks!
Old Feb 15, 2016 | 11:06 PM
FFDP's Avatar
Use the KISS method.
Stock intake and stock throttle body will work perfectly fine, no reason to upgrade those.
You'll need/want 60lb or 80lb injectors at least to be 100% safe and use brands with known good reviews and injector data for tuning.
A new fuel pump will be needed to keep up, like a 250 walboro or similar for a lower HP build. Not sure about a regulator and what you'll need there. Stock size lines will handle the fuel flow.
Stock bottem end will hold up to 650+whp on that 6.0 for sure, so not an issue for you. Stock camshaft should be able to get you too 500hp aswell, but upgraded valve springs are a must in my eyes.
cfaluck13
Oct 16, 2016 04:05 PM
40series
16
Mar 17, 2016 12:19 AM
EATSGTS
Jan 19, 2016 06:44 PM
ss4chad
Jan 13, 2016 10:22 AM
