first track runs with setup and a blow head gasket
Old Nov 14, 2009 | 05:49 PM
  #51
2004SSS's Avatar
sucks man , i know how it is to blow a head gaskettoo i just pushed water out mine on my 11.1 run.dont get discouraged with the down time its part of the game .Sucks you killed a trick flow head. i have the same heads on my 427 with a couple extra bolt holes. good luck and get it back up and running soon
Old Nov 14, 2009 | 06:24 PM
  #52
05crew's Avatar
i just got the trick flows. i took out the stock 317 heads...lol, im all good, i was a lil discouraged but i was able to find a lsx block. so all should be in on monday and get started with the new motor...#2,,lol
Old Nov 14, 2009 | 06:34 PM
  #53
LsxCody's Avatar
My truck should be running in a couple weeks. So yea I might go
Old Nov 14, 2009 | 06:46 PM
  #54
TURBHOE's Avatar
are you going with the 6 bolt heads?
Old Nov 14, 2009 | 06:48 PM
  #55
05crew's Avatar
yep ill have pic up soon of the block and heads. heads are here but block is not....
Old Nov 18, 2009 | 08:47 AM
  #56
cablebandit's Avatar
9 Second Club
go straight to c16 and drop the meth. Use the meth with any other fuel but c16...research "reid vapor pressure" especially c16 rvp vs other fuels
Iron block and afr heads is a sturdy combo. With c16 you should be able to push that combo to some big power. 93 is just not the fuel to use with the loads you are seeing. You dont need c16...more likely 104 octane but c16 allows a lot of tuning errors without the motor eating itself.
Old Nov 18, 2009 | 11:26 AM
  #57
Rick_Vor's Avatar
If he doesn't need C16 and assuming the right tune, won't he make more power with a lower octane fuel? I've already read that the higher the octane, the slower the burn rate.
Rick
Old Nov 18, 2009 | 07:23 PM
  #58
jow02327's Avatar
you might have mentioned this and i just didn't see it, but did it mess up the internals or just the block and the head?
thanks,
Jed
Old Nov 18, 2009 | 09:00 PM
  #59
reiners88's Avatar
higher octane fuel does burn slower but it allows you to run a more aggresive tune and more boost without the dreaded spark knock.
Old Nov 30, 2009 | 06:27 AM
  #60
9 Second Club
Rick
yes but until he gets everything nailed down c16 is cheap insurance vs a motor. I have been at 13.3 afr before at the 1/8....car slowed down a little but didnt hurt any parts. If he wants to run the meth then try sunoco maximal with the meth. its 116 octane as well. He already lifted the head on his first pass on the last combo...just trying to save him some pain.
