First Magnuson TVS2650 on a truck
Old Jun 3, 2019 | 10:46 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
He does in fact work for Magnuson.
Old Jun 4, 2019 | 08:48 AM
  #32
Vortec350ss's Avatar
Congrats Hubert.
The truck is running awesome.
Old Apr 20, 2021 | 11:53 PM
  #33
Humaid's Avatar
What accessory drive you are running?
Old Apr 21, 2021 | 10:17 AM
  #34
terravast4's Avatar
yes. Does this kit work with the truck accessories spacing? My understanding is you only need square port heads and then its just a bolt on other than the air intake routing.
Old Apr 21, 2021 | 11:17 AM
  #35
Humaid's Avatar
It should work with truck spacing but I don’t know what tensioner and idler was used. Also the belt path is different from the truck.
Old Apr 21, 2021 | 01:28 PM
  #36
terravast4's Avatar
I wonder if you could use adapters from square to cathedral ports and use an existing 2300 bracket
Old Apr 22, 2021 | 01:43 AM
  #37
Humaid's Avatar
I have a Magnuson tvs1900 on my truck. First I contacted Magnuson about the tvs2650 if I can fix it with my current accessory drive, but unfortunately they told me that the head units are not interchangeable.
Regarding the adapter no one have test it with tvs2650, however if it worked with LSA it should work with tvs2650 the only problem you may face is to match the port size of supercharger and the adapter.
actually I contacted so many companies and all of them don’t recommend to run tvs2650 on a single belt as they are concern about belt slippage. You can see that they sell supercharger for Camaro SS from 2010 tell know 2.9 or 2650 and running on a single belt.
most companies recommend to switch to LSA setup to run the supercharger on a separate belt. People with corvette or camaro will have less part to swap.
for truck accessory drive you will only use the alternator.
Old Apr 23, 2021 | 06:21 AM
  #38
Boosted_07's Avatar
Nice times man. Truck is moving..
Vortec350ss
Dec 16, 2017 02:18 PM
pufreak
Dec 13, 2006 02:15 PM
Moddoo
Jul 29, 2006 08:33 AM
datdude
Jan 23, 2006 03:43 AM
