Finally dynoed! Need help
Old Jun 4, 2007 | 11:07 PM
BlownChevy's Avatar
blownerator
25 Year Member
There are some things you need to get figured out before you go ANY further.
1) What is your boost level, this is important
2) IAT's with the radix are going to be high unless you keep a fan on the H/E at all times during the pull
3) Timing is low for what I assume to be 9-10 psi +/- 2 psi with the heads and cam set up.
4) Belt slipping?
There is alot more that I can explain on the phone when you call tomorrow...dont get discouraged....500 RWHP does not just COME to ya, you need to work for it
Old Jun 4, 2007 | 11:08 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by cyazo6
My goal was to make close to 500rwhp. I've seen some guys on here close to that, well look at trever1t's numbers for example. I am a little jealous!
I will definitely be spending a fair amount of time at NED once this thing is tuned right!
Again, Dyno's are tuning tools and nothing more.
I am very fortunate that all of my parts are working well with each other (knock on wood) and the L33 engine is a little unique to begin with. I also have the benefit of having one of the best tuners in the country close by. We have spent hours and hours detailing the tune to where I was satisfied.
I would think with the 2.8 pulley that you make 9lbs? Get the methanol going and add some timing, you'll get there.
BTW my next engine will be an LS6 so get it right and save me some grief
4) Belt slipping?
Yup
Old Jun 4, 2007 | 11:17 PM
cyazo6's Avatar
Thank you Brian for takeing the time tomorrow to help me out.
BTW my next engine will be an LS6 so get it right and save me some grief trever1t
Nice, LOL
Old Jun 4, 2007 | 11:23 PM
BigTex's Avatar
Do you have your crank pulley pinned?
With that size cam, I'd expect a higher peak power number and for it to extend further in the rpms.
Oh yeah, 133* is pretty low actually. Ask most of us on here who have pushed the radix to its limit and you'll find most of us have seen +180* IAT temps by the end of a long run.
Old Jun 4, 2007 | 11:26 PM
cyazo6's Avatar
Just real quick
1. I am not sure on the boost, but will have a definite answer tomorrow
2. There is a big fan right in front of the truck. I have a LFP Ford lightning heat exchanger mounted under the frame rails.
3. I am sure your right!
4. I have the 100mm idlers and as far as I know there is no belt slip.
Old Jun 4, 2007 | 11:28 PM
cyazo6's Avatar
Ya, the crank is pinned. I didn't relize you guys got the IAT's that high.
Old Jun 4, 2007 | 11:30 PM
BigTex's Avatar
Yeah, and most of us are throwing a little more timing at it too. With my LQ9 and 2.75" pulley and 218/218 114 cam, I was running 18-20* timing and shifting in the 6300 rpm range. No meth or water injection.
Old Jun 4, 2007 | 11:32 PM
cyazo6's Avatar
Just curious, but what did you pull for numbers or what did you run in the 1/4?
Old Jun 4, 2007 | 11:39 PM
BigTex's Avatar
12.31 @ 109 and 465HP 515TQ with a spinning crank pulley.
I had two dynos done within a week, one as normal and the other I pulled off the mufflers and cats and iced down the coolant. Both were going up rapidly then hit the 46x mark and flat lined. There was about 2 HP difference between them. Thats when I realized my crank pulley was slipping on the crank snout.
Old Jun 4, 2007 | 11:52 PM
cyazo6's Avatar
No kidding! I'd be very happy to run a 12.3 with my truck. I assume you nver pinned the crank and went back? Those numbers are great with a slipping crank pulley!
