FI'd LS9 for ZR1
Old Nov 27, 2007 | 10:26 PM
  #31
thunder550's Avatar
High on diesel fumes
Originally Posted by vanillagorilla
Tensioner?
Old Nov 27, 2007 | 11:27 PM
  #32
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by XLR8NSS
Anyone notice the blower pulley looks to be a pressed on type of deal? Looks like they are trying to make it tougher for people to put on a different pulley. Wonder if there is any sorta tamper device built in that "breaks" if you mess with the pulley? NO WARRANTY CLAIM FOR YOU!!!!
On the lightnings they put a dab of paint on the blower snout so when you swap a pulley it messes up the paint and no more warranty.
Old Nov 28, 2007 | 06:39 AM
  #33
dan96z71's Avatar
Or you just put another dab of paint on it when you are done...or do the crank pulley. But on this engine it doesn't look like you could go much bigger on the crank pulley because there isn't much room left.
Old Nov 28, 2007 | 02:48 PM
  #34
vanillagorilla's Avatar
Originally Posted by thunder550
Tensioner?
That's one funny looking tensioner.
For 6 figures, you'd better be able to change the pulley on this thing and up the boost!
Old Nov 28, 2007 | 03:02 PM
  #35
XLR8NSS's Avatar
Adkoonerstrator
Kinda looks like the pivot point of the tensioner and the arm goes behind the belt to that little pulley.
Old Nov 28, 2007 | 10:13 PM
  #36
1slow01Z71's Avatar
You cant see the paint unless you use a black light, and I doubt anybody knows where to get the paint.
Old Nov 28, 2007 | 10:17 PM
  #37
That's easy. It's a store in the mall called Spencer's
Old Nov 29, 2007 | 10:19 AM
  #38
OnyxSilveradoSS's Avatar
Originally Posted by syclone0569
old news.........he..he... i saw this in a denali in june.
enjoy and drool!!
damn!! any deatils
thats a transplant?? not on the truck block...or is it?? I was told by some guy it wont make it on a genIII engine, I wanted to tell him "you dont know the truck guys!"
Old Nov 29, 2007 | 03:26 PM
  #39
TURBHOE's Avatar
looks like it has two air temp sensors too.
Old Nov 29, 2007 | 03:42 PM
  #40
ForcedTQ's Avatar
It also appears to have a Vaccum to Boost ratio referenced bypass valve that has an electronic control valve. These are the black lines that run from the manifold before and after the supercharging chamber to the control valve, which is to the right of the throttle body connection. Could be that they will have the PCM control the availability of boost to the motor?
