which FI is better for a stock 5.3
#73
[QUOTE=06murder;4536471]yeah...but it be nice to run 10s[/QUOTE anything is possible my friend anything with a little time sweat and money anything like I said 5 .3 already went in to 10s chek out the vid on the thread they did
#75
I can't stress enough how much you need to just read on this site. Gather some basic knowledge first. I'm sure if you paid someone to spec and build this truck up for you, you could just jump into a fast daily driver. With a $13k budget, you could do that. But if you want to do this yourself, you need to learn a lot. If not, just shell out the cash and have someone do it for you.
#76
IMO I would stick with the 5.3l because you can achieve your hp goals with it. It will also be easier on the gas than a bigger cube engine would. A tvs 1900 along with a custom speced cam is very capable of 450hp if done right with other supporting mods. That will be the route I go when money is available...
#77
Dude, you seriously need some basic automotive engine building knowledge before you go dumping thousands of dollars into your truck. People on here are being alot nicer than they should be and offering you VERY good advice. Do some research on how a supercharger and a turbocharger work, find out the differances between a maggie and a procharger. once you know all this type of stuff you will be able to make a decision on your own. Everything you need is right here under search.
#79
yeah if i had to do it again i would start at the *** end of the truck and work forward. trutrac out back at the least. stock g80 doesn't like much power. then a level 7 flt trans with billet parts circle d or yank converter. not a tt3000 but the tc line from yank. then with that model 5.3 turbo that dude. if my 5.3 in a 6020lb tahoe can hit low 12's i'm sure a pickup can do it with ease. fuel sys and heads /cam and you'll be good. had you had a newer model you would already have good heads to start with.
Thank you. Don't forget about some 4.10's...
#80
GFYS and STFU
I can't stress this enough either...alot of us have been where you are, "A pocket full of cash and a desire to get noticed", and far too often we end up burning through that cash with nothing to show.
Put that fire out from under your pants, search around and find out what it is you want and then ask us some specific questions rather than the generalized ones your asking us now.
