few questions
Old Apr 21, 2009 | 03:05 PM
orange1500hd's Avatar
Default few questions
have a few questions about a fuel pump and couplers for my turbo. im going to put a walbro 255 this weekend before i put the turbo on, my fuel gauge is wonky so it need to be done anyways. the pump i have is the standard pressure one, should it be the high pressure unit? i don't think il be going over 500hp for a while. also the throttle body and mass airflow are 3.75''. are 4'' couplers ok for that and just suck it down with a clamp?
Old Apr 21, 2009 | 03:15 PM
idahoblkss's Avatar
walbro 255 is what i have and im running 8-9lbs of boost , but i put 44lb injectors in too, did you change your injectors?
Old Apr 21, 2009 | 03:44 PM
Mort's Avatar
They make silicone couplers in 3.75", may as well use them!
Old Apr 21, 2009 | 04:01 PM
DrX's Avatar
DrX
Both versions of the 255 will flow around 50 gal/hr at 60 psi. At higher pressures the regular version drops off quicker because the relief valve opens sooner.
Old Apr 21, 2009 | 06:27 PM
i have 44# injectors going on when the turbo goes on. guess i didn't look hard enough for those couplers i see extreme psi has them but i do already have one 3'' to 4'' coupler i was thinkin about using for charge pipe to maf
Old Apr 21, 2009 | 07:24 PM
so i tried the coupler it fits pretty good, don't think there will be any issue with it. just gotta tighten the clamp a bit more.
Old Apr 22, 2009 | 01:44 PM
found this video on youtube about walbro pumps, i tried mine out for a second (yeah i know its bad, was just for a sec) mine sounds like the supposed fake more than the other one. i did buy mine from a local place and even asked them if they had any come back, he said not any had come back....any thoughts
http://www.youtube.com/watch?v=7102y...eature=related
the pump i have is a unit #F20000169 on the pump not 341 or 342. seems to me that the gss340 341 and 342 are the ones being copied. am i getting paranoid?
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
