fabricators/welders need some ideas/help
Old Nov 4, 2007 | 07:13 PM
Yukon 400's Avatar
You can weld 1 3/4" nipple on the intake pipe, and find a radiator hose that has a 45 degree bend in it that is long enough to stretch between the bov and nipple. That would cheaper and easier than fabricating a piece of aluminum pipe.
Old Nov 11, 2007 | 11:47 PM
Turbo 6.0's Avatar
It seems like the cause of the problem is excessive crank case pressure causing a oil return problem. Have you tested to see if that is the case?
TouchOfEvil04
Oct 27, 2007 12:05 AM
TouchOfEvil04
Oct 26, 2007 09:41 PM
